99 fuel pressure regulator help
Old Feb 6, 2013 | 07:56 PM
junk c5's Avatar
junk c5
Default 99 fuel pressure regulator help
I've been doing lots of reading and figured out the fpr in a 99 vette is in the fuel filter mounted on the rear driver side frame rail. I added an aftermarket magnafuel fpr and external pump and I'm trying to figure out how to bypass the stock fpr. I'm running a return off the new fpr back into the tank so should the stock return be plugged? I was hoping the fpr was near the sending unit but it wasn't , I peeked in there. Any help would be great.
