P0133 and P0153 paging Bill!
Car is an 02 z06 with 38k. Installed the factory o2 sensors back in the car, maybe i should have bought new?
Had the car tuned on Tuesday, took it out for a spin this morning have put about 30 miles on it since the tune. Jumped on it and got a cel light.
Current dtc p0133 & p0153
What to do now? Have the sensors gotten lazy and should they be replaced, after all they are ten years old now?
Thanks for any help provided.
The very latest O2 sensors from GM are a different design than before. You might give these a try, I believe they will respond faster. It's not a ton of money to find out.
The stainless works are a rather long header which contributes to the problem.
You could also have those codes simply turned off, they are more of a nuisance than a problem.
Not that it makes a hill of beans difference, I have the XS power headers which are a bit shorter, and also had them coated in an effort to keep the heat in. I have those DTC's active and have had had no issues at all. I'm using the latest AC delco sensors as well.
A photo of the difference:
Ron
FWIW....you can turn off every error code with HPT......
