DRM Headers?
Old Jun 14, 2002 | 04:54 PM
raygr's Avatar
raygr
Default DRM Headers?
Can anybody comment on the headers sold by Doug Rippie? I'm not sure if DRM makes it, or just resells it. http://www.dougrippie.com/drm/exhaus... - C5 Corvette
A local shop here says they are very nice and fit well.
Old Jun 14, 2002 | 04:56 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Default Re: DRM Headers? (raygr)
He just redesigned them but I doubt he makes them. They don't sell junk. They are nice looking and fit well I'm told, some have them on the forum.
[Modified by John Shiels, 3:58 PM 6/14/2002]
Old Jun 14, 2002 | 05:59 PM
Cha Cha's Avatar
Cha Cha
Default Re: DRM Headers? (John Shiels)
The shop that installed mine could not say enough good things about them....They were quite impressed with the ease of the install and I experienced 20+HP gain at the rear wheels..
Old Jun 14, 2002 | 06:16 PM
no cure's Avatar
no cure
they probably do not fab them in house, but when I got mine 2 years ago, Peter said that they were made from a proprietary jig which doug had delveloped and that they were Not a knock off of someone elses.
anyway, I've had mine on for ~ 23k miles, not a hitch, leak, ping or other prob, they have worn great, and imho they are better made than many others. I've side by sided my car with other long tubes from a few different manufacturers, and drm ones clear the spark plugs the best, imho, and have the best spacing for heat disapation, imho. I've not seen em all, far from it, I'm not knocking anyone elses work, I'm just a happy customer..
I see you're local, next time I'm doin the triple X cruise in you can see em first hand if ya want..
David
Old Jun 14, 2002 | 11:13 PM
ZZ's Avatar
ZZ
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VII Veteran
I have DRMs and have been very pleased. The tuner doing my current project was impressed with them, and advised I use them on my present project instead of some custom GM Racing ones he had made.
ZZ
Old Jun 15, 2002 | 02:30 AM
raygr's Avatar
raygr
Default Re: DRM Headers? (no cure)
Sound like the DRM headers are nice pieces. I feel a compulsion to order them....
Well now, I stop by there on Saturday eves once in a while. I live only a mile or two from there. The folks at Carb Con in Kirkland recommended the DRM headers highly. I'm planning to get a baseline dyno test done next Tuesday there. :cheers:
Old Jun 15, 2002 | 02:46 AM
no cure's Avatar
no cure
yeah, Alex the owner is a bud of mine. after they saw my headers they were sold on rippie :)
always good to get a baseline.
you going to come out to a road course event?
Old Jun 15, 2002 | 02:31 PM
Mako's Avatar
Mako
I run DRM 1 3/4" Long Tubes on my 427. NO problems! The only issue to consider is the collectors. I have a 3" custom exhaust and the DRM collectors are not the optimal "merge collectors" and are 2 1/2". I have such sick amounts of power everywhere that I have not bothered to change the collectors or the headers.
Most people do not need 3" collectors. Also, DRM may have improved this design since my buy 8mos ago.
The only other headers I would consider are the LGM SS ones with merge collectors--awesome pieces, but more $$$.
Old Jun 17, 2002 | 04:56 AM
raygr's Avatar
raygr
I would like to. First, I have to figure out what kind of roll bars I can get in my convertible, and who can install it.
What group do you go to road course events with? Do you go to SIR?
Old Jun 17, 2002 | 01:16 PM
Lawdogg's Avatar
Lawdogg
Active Streak: 90 Days
Default Re: DRM Headers? (Mako)
My DRM headers dynoed 19 rwhp and 19 rwt increases when my car was otherwise stock. I believe DRM has recently improved the collectors as Mako described. Fit and finish are top notch. :yesnod:
Old Jun 17, 2002 | 01:48 PM
no cure's Avatar
no cure
many different groups. go to sir all the time. amongst others. total blast.
there's a local fellow with c5 vert with really nice (removable) roll bar. quite the involved custom installation, but worth it if one has a vert an wants to get on the road course.. he put it in himself, but many use a local shop that easily has skill set for this..
To DRM Headers?
