Ported Throttle Body
Old Jun 14, 2002 | 07:38 PM
Vettepartz's Avatar
Vettepartz
Default Ported Throttle Body
Does anyone have pictures of their throttle body before and after porting?
Old Jun 14, 2002 | 09:24 PM
Jim 47's Avatar
Jim 47
Default Re: Ported Throttle Body (Vettepartz)
I guess not. :eek: But I just installed one on my 2000 FRC, along with the previously installed Twin K & N filters, Granatelli MAF sensor, and coupler, and got a large leap in HP. It works for me. :D
Old Jun 15, 2002 | 02:22 AM
MDL-01C5's Avatar
MDL-01C5
Default Re: Ported Throttle Body (Jim 47)
Well-- did you take any pics?;)
Old Jun 15, 2002 | 04:46 PM
Vettepartz's Avatar
Vettepartz
Doesn't anybody do their own porting anymore?????
Old Jun 16, 2002 | 11:27 AM
C5Cemo's Avatar
C5Cemo
Here's what mine looked like right after the intial work. I have since done some polishing to increase velocity and lower turbulence...
I also decided to epoxy up the PCV inlet valve for better flow characteristics and to keep any nitrous out of that system. I got 5 Rwhp corrected with the change before the polishing work was done.
:cool:
Old Jun 16, 2002 | 11:55 AM
dads01dream's Avatar
dads01dream
Default Re: Ported Throttle Body (C5Cemo)
What did you do with the PVC now that it's blocked off? Could you tell us how much you opened her up? What is the original diameter & the modified opening?
Sorry for all the Q's, but I did this little mod before on my 5.0 mas air meter and it made a nice difference too.
Old Jun 16, 2002 | 12:12 PM
C5Cemo's Avatar
C5Cemo
Default Re: Ported Throttle Body (dads01dream)
I've got a small K&N breather feeding the PCV system now. It has worked very well for me.
Here's a pic shoing this arrangent:
Old Jun 16, 2002 | 01:42 PM
SNW Vette's Avatar
SNW Vette
Hi,
This site has before and after pictures.
http://community.webshots.com/album/39963271faXnfe
Porting the TB does not open up the minimum bore of the part. The bore is matched to the size of the throttle plate. It is not a common mod to fit a larger plate. BBK does make a TB with a bigger bore size.
The stock TB is a casting that is then machined with a simple straight bore. The intersection of the bore and casting are not blended at the factory so we have an opportunity to reduce the flow losses with some hand blending and polishing. Do not grind the area where the throttle plate intersects the bore! This area controls the idle air flow vs. throttle position and needs to stay very close to the stock relationship. Fortunately, this is not a real limitation in blending the TB casting to the bore. I went around the closed throttle plate with a marker as a guide before starting to grind.
The PCV cutout can be handled in several ways. The minimum mod is to just round off the edges. A bigger mod is to use metal filled epoxy and reshape the area to follow the contour of the surrounding bore. Most people leave several holes (the size of soda straws) in the epoxy to feed the PCV system.
Other areas to improve are the throttle plate which has sharp blunt edges, the fasteners that stick out into the flow and the thickness of the cross shaft. You can improve these areas with some careful work. Only grind the throttle plate edges on the sides that do not touch the bore. This is for the same reason that you don’t grind the bore. You can radius the bottom-front and the top rear of the throttle plate leaving a sharp edge on the opposite sides to keep your idle flow relationships. Most people thin the shaft and remove any threaded potion that is sticking out in the flow. Let your conscious be your guide (and the pictures).
Take a good look at the pictures. You may also want to go to several tuner web sites to see what they do.
Good luck,
Steve
:seeya
Old Jun 16, 2002 | 09:03 PM
dads01dream
Default Re: Ported Throttle Body (SNW Vette)
GREAT PICS!! Did you get the TB chromed or is it just painted chrome? If painted, please let me know the brand of paint.
Thx!
Old Jun 16, 2002 | 09:08 PM
dads01dream
Love the K&N trick!! Man, I can't get over how creative you list members are! Could anyone tell me why the PVC draws air from the TB like that? Does it have any effect on airflow to the motor being in this location?
Thx!
To Ported Throttle Body
