Rear clunk noise
Old Feb 15, 2013 | 06:28 AM
thorn92's Avatar
thorn92
Default Rear clunk noise
I've read many post on the rear clunking noise but still haven't found a solution to my problem. I have a 2000 coupe and when I hit a bump or recess in the road, I hear this awful "loose" sounding clunk from the rear. I replaced the shocks last week, the sway bar links and ensured everything else is tight. It sounds like the hatch is bouncing. I adjusted the stoppers to where there is no play whatsoever and when I check for any travel, none exist. I'm at a complete loss. Is there something I'm missing? Thanks!
Old Feb 17, 2013 | 07:56 PM
1blkc4's Avatar
1blkc4
I had the same problem try to shoot some grease on the cv axle splines and torque to 116 ftlbs
Old Feb 18, 2013 | 11:53 AM
thorn92's Avatar
thorn92
Thanks! I'll try anything at this point. Grease as in actual grease or WD-40,PB Blaster, etc?
To Rear clunk noise
