I'm in the market for headers for my stock 01 Z. I don't plan on heavy mods for the motor, I have enough power for the track.
I asked the forum what size I should get. I got enough replies telling me 1 7/8 with 3" X pipe because I won't lose any power in the lower end, compared to 1 3/4 and I will actually gain more power in the top end. I liked that.
I want to bring my headers to the popular Washington tuner, Tom Wong. I asked if he agreed with the 1 7/8; he told me to get 1 3/4 because it will make better torque. I didn't want to be a newbie idiot to an expert and reply "Well I heard on CF that blah blah blah blah...."
Should I just get over it and realize I'll be fine with LG streets or maybe meet halfway and get the LG superpros?
It would be lame to have to switch sizes in the future because I changed my mind and wanted to slap more power in the motor.
What are your guy's thoughts?
Sometimes I just need somebody to set me straight
Thanks guys!
You need to define what your ultimate goal is with engine mods and then buy the headers accordingly. 1 7/8" tubes on a stock engine are not going to give you a lot of added power. Had a friend that put these on and only gained 12 RWHP after a tune. Two years later he did the full heads, cam and cold air routine and was moving enough air that the larger size was necessary. If you are going to stay basically stock the 1 3/4" will deliver the most power. If added H & C mods are in the future - go with the 1 7/8"
Get over it. Your tuner is the one you should trust. If you don't you shouldn't be using him.
If in fact you are going to keep your engine stock then you should be trying to improve power (torque) below the curve. That is where you will get the most out of a stock engine. If you decide later that you want a little more, there are several cams out there that add huge amounts of torque below the curve and will work quite well with 1 3/4 headers.. It seems to me that most people are more impressed with BIG sexy numbers than they are with what works best for a street driven near stock car. Don't get sucked into that "my dog is bigger than yours" game that is mostly played by non pros.
Your not saying what mods you have now but you are saying you don't have plans for heavy mods in the future. Reading that I would think that 1 3/4's should be fine. It really depends on your current/future mods and how your using the car.
GL
Chris
Thanks guys!
Tom has dynoed a ton of these cars. Trust him, you will be fine. If you can stand the time, and the money, wait for the Pfadt 4-2-1 headers. They will be better everywhere.
BTW...the 1 7/8 make the extra hp at the top of the rev range, where you will likely spend very little time unless you are racing the car.
Also keep in mind anything bigger than 1 3/4 might require you busting out the saw.
I had to cut a lip off my frame that the 1 7/8" Kooks were banging against.
Another good, cheap alternative is to get a C6Z manifold setup. You can get the manifolds, cats, and midpipes for $350 on this forum. I am running that setup now and I love it. They will make almost as much as headers.
I say 1 3/4" is the way to go too. Especially on a street car. Torque is the most important thing to keep up on theses cars. The 346 is hard enough to maintain torque on because it is a relatively small CID. The 1 7/8"are to large if you are not running a decently aggressive H/C or FI setup.
....Another good, cheap alternative is to get a C6Z manifold setup. You can get the manifolds, cats, and midpipes for $350 on this forum. I am running that setup now and I love it. They will make almost as much as headers.
Will that set up bolt on to a C5 w/o any modification?
Basically you just have to take the end of your stock c5 midpipe and splice it into the c6 midpipe so it connects to your mufflers. You can do this with $20 3"->2.5" adapters. Easy peasy.
Then other little odds and ends. Like for me, I had to file a tiny edge off my bellhousing so the cat would clear. Not a big deal at all.
Everything you need is detailed in that thread. Just gotta dig through it.
I can only speak from my own experiance. I have ARH. 1 7/8 " headers . I noticed the most gain above 4500 or so. Pulls hard all the way to rev limit of 6800. They work great with my 3.90 gears. Its easier to control wheel spin. In my case the bigger headers worked out great.
Thanks guys!
Based on what you're stated usage is: 1 3/4"
Btw, FWIW Kooks has recently done a redesign on their C5 headers to make them easier to install. Both they, and ARH are very high quality products.
Just did a Heads,cam, Header job on my car.. I went with 1-'3/4 and 3" mid section... I was concerned about losing power down low with the larger 1-7/8..
A lot of conventional wisdom in here. I've heard a few times, even spoke with a tuner about this, and he stated that even on a stock engine, the bigger headers lose nothing down low. Of course, the gains up top are negligible, on the order of ~8whp from 5000+, but it's 8 more than you get with 1 3/4" headers with no penalties elsewhere. Seems like a win/win scenario to me. For some reason, bigger is better in this scenario. In order of what he made the most power from least to most is LG Super Pros, then 1 7/8" Kooks, then 1 7/8" ARH. Some serious bang for the buck would be some el cheapo 1 3/4" headers, but if you're looking to blow 1500+ on them, just get the ARHs or wait for the Pfadts.
K guys I appreciate all the help! I am going with the tech's advice and buying ARH 1-3/4 with 2.5-3" x pipe (# C5L34WC).
I am looking forward to getting them in!!
Thanks again for the input and "settin' me straight!"
ARH are top-quality headers & fit/install the best
i've got their 1 7/8 on my LS1... but then again, i'm also running 11psi off a TVS with a stroker coming later
