AC belt replace?
Old Jun 15, 2002 | 12:15 AM
c5a4's Avatar
c5a4
Default AC belt replace?
My ac belt needs to be replaced and I was wondering if it can be changed from above or does the car have to up and done from below? I changed the big serpentine belt and put a new tensioner on but the ac belt looks tricky and I dont have a jack.
Old Jun 15, 2002 | 09:20 AM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: AC belt replace? (c5a4)
I don't have the answer but I will bump it up for ya :cheers:
Old Jun 15, 2002 | 09:26 AM
Arkay's Avatar
Arkay
I am 99% sure it can be done from above as I just had one replaced at the dealer and I do not recall the car going up on a lift. Something was making all kinds of noise and they replaces the belt and some other stuff.
Old Jun 15, 2002 | 10:12 AM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
If you have an A4,the trans cooler lines are in the way of the tensioner and it is easier to get a wrench on the tensioner from below,with the wrench facing downward...If you have an M6,you can probably access the tensioner from above :yesnod:
Old Jun 15, 2002 | 11:18 AM
c5a4's Avatar
c5a4
Default Re: AC belt replace? (C-5 TECH)
Thanks for the info. I have a A4 trans so it looks like my best bet is to take and have it put on from below. Any idea what it might cost if I go to a shop. Or is it worth going out and buying a jack and stands?
Old Jun 15, 2002 | 01:11 PM
lotzahp's Avatar
lotzahp
It can easily be done from above. Take off the serpentine belt, and its tensioner. You have enough access to get a wrench (not a socket) down there. I did it on my 98 A4 several times.
Old Jun 15, 2002 | 10:39 PM
c5a4's Avatar
c5a4
Default Re: AC belt replace? (lotzahp)
Thanks, I will give that a try the first of the week. Is the bolt on that tensioner 15mm also?
Old Jun 15, 2002 | 11:41 PM
lotzahp's Avatar
lotzahp
yeah, both tensioners are 15mm.
Good luck, it's not hard. I bet you're done in under an hour.
Old Jun 16, 2002 | 04:46 PM
c5a4's Avatar
c5a4
Thanks again,I just got through and it took about a half hour. I was almost ready to go to a shop and pay till you gave the good info. :)
Old Jun 16, 2002 | 06:10 PM
lotzahp's Avatar
lotzahp
happy 2 help :cheers:
To AC belt replace?
