Do stock C6Z06 headers Fit a C5?
Old Feb 18, 2013 | 01:12 PM
demonio1023's Avatar
demonio1023
Default Do stock C6Z06 headers Fit a C5?
Hi guys,
need your help here, has anyone installed stock C6 Z06 headers and midpipe on a C5? Does it fit? I searched and could not find anything.
I have a friend with a C5 Z06 and he wants to buy my setup but I am not sure if it would fit. Thanks in advance for the help
Old Feb 18, 2013 | 01:28 PM
Alex99's Avatar
Alex99
Yes they fit with very minor modifications.
Search again, because there are at least 2-3 threads with detailed information about it.
Old Feb 18, 2013 | 01:29 PM
chevy406's Avatar
chevy406
The LS7 exhaust manifolds will bolt onto LS1 cylinder heads. I don't know if they will interfere with anything in the C5. But they will certainly need custom pipes to meet up with the C5 exhaust. It will not be a bolt-in swap.
Stock C5 manifolds:
Stock LS7 manifolds:
Old Feb 18, 2013 | 03:06 PM
demonio1023
Thanks Alex, I searched again and found both Threads. The keyword was manifolds. Thanks again!
Old Feb 18, 2013 | 03:08 PM
demonio1023
Thanks for the reply I saw on the other threads that they fit just fine.
Old Feb 19, 2013 | 12:55 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
If you found the thread then you also seen my posts and pictures along with others too!
I have done this already and am waiting for my B&B Fusion (Bi-Mode) 3" all the way the axle!
If your friend is going to do this there is NO need for him to drop down to 2 1/2" mufflers - he can continue the 3" all the way over and be fully slip fit like the Z06 etc.
If he has questions you can have him call me about this set-up too and fitment etc. 661-406-7516
Thanks,Matt
661-406-7516
Old Apr 19, 2013 | 06:41 PM
madmatt9471
Dyno Update - results are in - 4/19/2013 - Big thumbs up to Charlie and Austin @ RPM Motors
First it was necessary for me to install a "PROPER" Crank Case Evacuation System - here is my write up on my Monster 2 Catch Can Installation with Pics -
Thanks to the proper guidance of Charlie I got headed in the correct direction and was able to get the proper set-up for my combo, I wasn't able to go any further a few weeks back specifically because of an INADEQUATE Crank Case Evac system
http://forums.corvetteforum.com/c5-f...ntri-pics.html
Dyno Results: I lost - .4 RWHP and 15 RWTQ - "NEW DYNO SHEET"
"OLD DYNO SHEET" -
Thanks,matt
To Do stock C6Z06 headers Fit a C5?
