Auto Climate Control Connector Pinout
Old Feb 19, 2013 | 10:21 AM
Zerochad's Avatar
Zerochad
5th Gear
Default Auto Climate Control Connector Pinout
I'm trying to troubleshoot an "always on" light problem with my HVAC control. Does anyone have the connector pinout for this unit? Thanks!
Old Feb 19, 2013 | 11:57 AM
dadaroo's Avatar
dadaroo
I will be glad to look it up in my 2001 FSM, should not be different from year to year. However, what type of HVAC controller do you have (dual, etc.). Once I know what you have I can scan the info and post. I am very curious about what would cause this. Exactly what light(s) are on (LCD and or others)?
PS: Could be a weird BCM issue, might want to disconnect/reconnect the battery and then see if that fixes it. Make sure you wait at least 30 to 60 seconds before reconnection.
Old Feb 19, 2013 | 02:24 PM
Zerochad's Avatar
Zerochad
5th Gear
I have the Automatic Dual controller. I'd appreciate it if you could post the diagram!
Backstory: I replaced my burnt out bulbs with LEDs with appropriate resistors a few months ago. Recently One of them shorted and caused a burnt trace on the board. I repaired the traces and short, but with the key removed, the lights would stay on (not the lcd). In another post someone mentioned replacing a voltage regulator fixed a similar problem caused by a short so I tried that to no avail. Having the pinout will help me troubleshoot the unit and verify if there is a power backfeed, or if it is indeed the BCM. I'll try resetting the battery when I get home though.
Old Feb 20, 2013 | 08:54 AM
dadaroo's Avatar
dadaroo
OK, here we go. Remember these are from my 2001 FSM but "should" be the same for most or all years. The first 3 are from the HVAC section, with the last 2 from the General Electrical section. It seems the are 4 pins that have voltage. C5, C10, C12, and C16 (which I think is the one that is remaining powered). I have not looked upstream to see if there might be a relay that has failed to cause power to be on. Let me know if you have any questions, or if I can do further research to help. I am curious to find out what it is, just hope it is not the BCM.
Old Mar 16, 2013 | 01:26 PM
uncle wilson's Avatar
uncle wilson
Tks for the schematic. Hunting c5 brown with no power! Where does it end ! Tks
Old Mar 17, 2013 | 08:11 AM
dadaroo's Avatar
dadaroo
It goes to a 10 Amp fuse #18 (HVAC) in the interior fuse box (passenger side). That fuse in turn is fed from the engine compartment fuse box. Let me know if you need more info.
PS: If you notice, that fuse powers everything in the lower right side of the schematic which is all HVAC related
Old Mar 17, 2013 | 06:03 PM
uncle wilson
The orange wire is also powered by no 18? Fuse was bad replaced orange wire nor hot brown not
Old Mar 18, 2013 | 08:56 AM
dadaroo's Avatar
dadaroo
No, the orange wire is providing power from the engine fuse box to fuse 18 in the passenger compartment.
Please clarify your second sentense with regard to what is or is not getting power. If fuse 18 was bad, how did you know? (just trying to get an idea of your electrical knowledge so I can best help)
Also, what year do you have? I assume you are working on a different car and issue from the original person who posted this thread.
Old Jul 11, 2021 | 10:20 AM
pjmny's Avatar
pjmny
4th Gear
Default AC/Heater control head non responsive.
My 1999 C5 climate control head is completely non-responsive. I removed control head and sent it out to be refurbished. After reinstalling it I now have only illumination behind the temp control *****. Nothing else is illuminated nor do any of the controls respond. As suggested by a previous post in the forum I checked connector pins C5, C10, C12 and C16. All have 12 volts coming to them.
i checked every fuse in both fuse boxes, all are good. Aside from the control head still being defective can anyone suggest a cure?
Old Jun 12, 2024 | 01:42 PM
Littleman55's Avatar
Littleman55
Default Corvette
I can command the a/c on with the autel scanner but a/c request still says no
Old Jun 12, 2024 | 10:01 PM
Ed Ramberger's Avatar
Ed Ramberger
As soon as I read this I was going to ask if you tried replacing bulbs and shorted something. I have seen this before and in those cases it fried a board in the climate control head unit.
Old Jun 13, 2024 | 12:07 AM
Littleman55
Yea I replied the pin connector to the back of the AC head unit but yea still can’t communicate with it on a scanner tool but look at it and did not see anything fried on it was wondering if it might be the PCM but I have got it to work by moving the head unit around and the AC compressor came on with out touching the button so don’t know what else ideas?
Old Jun 14, 2024 | 06:31 AM
Moved to C5 Tech.
Old Jun 14, 2024 | 09:51 AM
Ed Ramberger
On one I looked at I couldn't see it but it damaged something in a board. I send everything to Travis Wolfe at Vetteronics/Wolfe Restorations. He uses the correct resistance bulbs and can tell you what got damaged. I had a damaged board several years ago and he sole me one for a very reasonable price. I have recommended him to several forum members who have all been happy. You can find him on facebook.
To Auto Climate Control Connector Pinout
