C6 Z06 brake upgrade
I'm upgarading my C05 Z06 brakes to C6 Z06 big brakes. The brake lines are different at the frame connection. Is there a conversion kit? Or what will I need to connect to the frame lines? Handy Andy
I don't know diddly about the swap specifics, but are you unable to use the C5 flex lines to hook up to the calipers? Not sure if they have the right fitting or not...
C5 Stainless Lines.
Not sure who's kit you've got, but you will need to use the C5 Lines.
Hope this helps,
Tom@Zip
1-800-962-9632 ext 240
Hope this helps,
Tom@Zip
__________________
Zip Corvette Parts and Accessories - Corvettes Are All We Do!
Selling Quality Corvette Parts & Accessories Since 1977
Corvette Parts Catalogs | Subscribe to our newsletter
Corvette Tech Articles | Corvette Parts Blog
Thoroughly chapped
Location: If you're not angry, you're not paying attention
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Just found this out the hard way....I ordered in the C6 Z06 s/s lines from StopTech. and they are 10x1.0 female inverted flare vs the C5's 10x1.0 female bubble flare. I thought I had researched this swap very well, but missed this little tidbit.
Short answer, yes. I am doing the same conversion.
The calipers bolt straight on. As tom@zip mentioned stainless lines with the C5 fitting. I purchased mine from Doug Rippie, one of our vendors, with great service.
Obviously other items needed are the C6z06 rotors and larger wheels to clear the front rotors.
I just did this myself (your going to love it), I was lucky enough to guy a kit that came with everything including the Motul fluid, hawk pads and the precut braided lines, it was a perfect fit and loos and performs awesome.
Make sure you take the time to apply a good coat of high heat black (or whatever) to the primed areas of the center of the hubs, it will keep it from showing signs of age longer and looks great
