I just wrapped it up. I needed the LC1 easilly removable, as I tune on the weekends for other people.
The LC1 comes out via a 6 pin connector I installed in the glovebox, and connects back up to a 6 pin connector that is attached to a wiring harness setup to easily install in any car.
I dont like stuff easily visible so I tucked everything in the glovebox, and mounted it all on velcro.
No holes drilled in the car, no permanent modifications were made to the car.
Everything is quickly reversible.
I need to reroute some of the wires to clean it up some, but for the most part I'm pretty happy with the install.
Nice setup. Clean.
Tip: Protect that RPO sticker on the GB door. It is non-replaceable and lists all the options by RPO code that came with your car. Those cords and devices WILL, over time, destroy that sticker. I would recommend a small micro-fiber towel/rag, etc to protect it. Something soft. Anything hard will just rub right through it.
Originally Posted by Kaploww
Nothing is touching the sticker or even close to it. It's a perspective illusion, but I will make an effort to protect it.
Thanks for the tip!
Fortunately for me, I was able to stop any further damage on mine after noticing the printing being being worn away from my routine glovebox content items.
