Whats the Brake bleeding sequence????
Actually I've heard it depends on the year. For my 2000 I did RR LR RF LF. Used a Mighty Vac II and it really made things a lot easier. :cheers:
You might want to research this a bit more. My understanding the RR LR RF LF is good for 97-99 but changed for '00 up. Maybe someone with more knowledge will chime in.
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
I installed the speed bleeders :D
does anyone know this for sure :) :cheers:
Elite Member
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Actually..WWC sent me some speed bleeders by mistake. So how do they work? What's their advantage?
CI III & IV Vote Ho
CI IV Bracket Champ
it's got a built-in "check valve" that allows you to continuosly pump the brake during bleeding, this prevents having to close the valve after each pump, avoiding the sucking in of air into the system.
10mm wrench and it's the little rubber covered nipple protruding just above the connection point of the brake line to the caliper :)
Elite Member
So in essence it makes bleeding the brakes a one man process?????? Oen the bleeder, get in the car, press the brake.................pump.............. press brake to the floor.........etc...........then close the bleeder????? :crazy:
CI III & IV Vote Ho
CI IV Bracket Champ
exactly.....setup something to catch the fluid coming out and pump the brake away...clear, bubble free liquid exits, stop pumping and shut the valve :)
and don't let the resevoir go dry :)
St. Jude Donor '05
I sat in the car and pumped the brakes on command. The mechanic started in the front and when to each wheel two times making sure all the air was out. He had to fill the reservoir twice, just like normal.
With the Mighty Vac I didn't have to get into the car and push the brake at all...don't even have Speed Bleeders. It took about 20-30 minutes to do them all. I used the Super Blue stuff and it made it real easy to see when I was getting fresh fluid. Good luck. :cheers:
Yes, as mentioned above I think it depends on the year as to which sequence you should use. Depends if your braking system divides, Fronts and Rears, or pairs them diagonally; one front with the diagonal rear.
Don't have acess to my manual for the 2001 right now or I'd look it up for ya.
Good luck.
Mark
Good luck.
Mark
