Automatic Filter part number (confusion)
Old Feb 23, 2013 | 02:21 PM
Plasticman's Avatar
Plasticman
Default Automatic Filter part number (confusion)
I see 2 different looking & different part numbers for the C5 auto trans filter.
Which is correct, or? These guys list both:
http://www.autopartswarehouse.com/sh.../corvette.html
List this one:
1997-2004 Chevrolet Corvette Automatic Transmission Filter - AC Delco - OE replacement
Part Number: ACTF306
Manufacturer number: TF306
AC Delco Automatic Transmission Filter AC Delco Automatic Transmission Filter
More Images
List Price:$38.89
Our Price: $32.96
You Save: $5.93
Quantity:
AC DELCO TRANSMISSION OIL FILTER KIT -- 16 holes; Includes pick-up tube; A high quality, OE replacement transmission oil filter kit; With 12-month or 12,000-mile AC Delco warranty.
And also list this one:
1997-2005 Chevrolet Corvette Automatic Transmission Filter - AC Delco - OE replacement
Part Number: AC24208574
Manufacturer number: 24208574
More Images
List Price:$60.53
Our Price: $51.30
You Save: $9.23
Free Shipping
Quantity:
AC DELCO AUTOMATIC TRANSMISSION OIL FILTER KIT -- A high quality, direct fit OE replacement automatic transmission oil filter kit; With 12-month or 12,000-mile AC Delco limited warranty.
Fit Note: Automatic Transmission, Car
Type: OE replacement
Quantity Sold: Kit
Fits the following 1997-2005 Chevrolet Corvette submodels:
2005-2005: Base; 8 Cyl 6.0L; "Gas, FI, Naturally Aspirated, VIN U"
1997-2004: Base; 8 Cyl 5.7L; "GAS, FI, Naturally Aspirated, VIN G"
Thanks,
Plasticman
Old Feb 23, 2013 | 05:46 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
If your transmission pan has a depression bubble on the bottom side, use the AC Delco TF306 filter. The filter pick-up tube length, on the TF306, is designed to reach to the bottom of that depression bubble in the pan.
Most C5's have the above mentioned pan, although a few early C5's came with a flat bottom pan and a shorter filter.
Old Feb 23, 2013 | 10:01 PM
Plasticman's Avatar
Plasticman
Quicksilver,
Thanks! Will check which I have and go from there.
Plasticman
Old Feb 23, 2013 | 10:06 PM
C5FORFUN2's Avatar
C5FORFUN2
I posted the same question a few weeks ago & found the same answer. I noticed some sites also included the Z06 in the list for the filter application.
I ordered this one ACDelco 24208574 Automatic Transmission Filter Kit. It matched what I took out when I serviced it.
Old Feb 24, 2013 | 11:02 AM
Quicksilver Vert 01
I seem to remember your question too.
There's a link in the thread below for checking the fluid level, which may be helpful to Plasticman after his fluid and filter change.
http://forums.corvetteforum.com/c5-t...a4-filter.html
Old Feb 24, 2013 | 12:34 PM
Plasticman's Avatar
Plasticman
Thanks for the link, and I found a deep bubble depression on my 2003 pan.
However, now I am confused again:
You said: If your transmission pan has a depression bubble on the bottom side, use the AC Delco TF306 filter.
However C5FORFUN2 said he used the other filter (I ordered this one ACDelco 24208574), and in the other thread stated that he had the bubble depression pan..................
And of course, while looking at the trans pan, found a good amount of oil film (plus some actual oil) at the bottom of one of the rear magnetic ride shocks...........ca-ching!
Thanks again,
Plasticman
Old Feb 24, 2013 | 03:26 PM
Plasticman's Avatar
Plasticman
Quicksilver,
Thanks again!
Plasticman
Old Aug 1, 2015 | 04:59 PM
ingalls71's Avatar
ingalls71
5th Gear
I used the TF306 and it doesn't fit. I have the pan with a bubble in the bottom. The pan does not set flush to the trans. It first appeared to be the pickup tube but after using some clay for reference that was not the culprit. It appears that it is just to big although I don't know how as it looks almost the same as the filter that came out which does not have a pickup tube. Go figure this one?
Old Aug 3, 2015 | 07:22 PM
ArtGle's Avatar
ArtGle
Veteran: Marine Corps
Default Transmission Filter
Here's a shot of my pan.
Dealer sold me the 24208574 Filter Kit.
Matched what came out.
Old Aug 3, 2015 | 07:26 PM
ArtGle's Avatar
ArtGle
Default The filter with the 'extension' tube
Filter in the transmission.
To Automatic Filter part number (confusion)
