Oily substance leaking INTO car at steering
So, while continuing my hunt for electrical gremlins, I discovered the following oily substance dripping down inside the cockpit from the steering shaft. Anyone have an idea what this might be from?
My thought as well as it seems to be the only fluid containing area nearby. I'll check the booster today and post.
BTW check out my post on "Gremlins", I've added a few posts.
Thanks RonSSNova
Thanks RonSSNova
Good thoughts. My mechanic had the car for awhile. I will ask him if he lubricated the column. I used a fiber optic scope to check the engine bay and there are no leaks. The steering column is shiny like new (and its a 2001) and find no leakage at brake master. So I wiped it up and will ask about lubricant. Will post when I have more. Thanks guys!
Results?
I realize this thread was posted 5 years ago, but there was no follow-up discovery posted. I have the same leak in my 2002 C5, but the brakes and steering work fine, the pedal movement is the same and the brake fluid remains at the max line, despite the drip line of lubricant and 3 inch diameter stain on the carpet. Did anyone ever find the cause/solution with their own C5?
Thanks in advance for sharing your wisdom and time!
Funny.....it still is directing instant email after all this time. Anyway, one of our brothers had mentioned it was likely original lube from the telescoping column. I think he was right. Also, recently I had to replace the steering wheel position sensor and had the whole column out. Nothing out of the ordinary or signs of leakage. Have not had brake issues. Lastly, the material was grease like as opposed to something like brake fluid. I cleaned it off.....nothing has returned. Hope that helps.
