Re: WHERE IS FUSE #25? .... "Service Column Lock" problem (Len16)
The interior fuses are located under the passenger side floor area. Pull up the carpet, and remove the "foot-rest" panel against the firewall. You'll see a black box with a center thumb screw to open it it.
Re: WHERE IS FUSE #25? .... "Service Column Lock" problem (C5pilot)
:yesnod: have a flashlight handy if you are in the garage since the fuse also cuts your interior lights
