Question about Trans fluid on the ground
Old Mar 11, 2013 | 12:52 PM
robert21122's Avatar
robert21122
Default Question about Trans fluid on the ground
Im doing my cam swap.I started last night, i had to take the line out of the radiator and it was leaking some tranny fluid out so i put the line up before i went to bed. This morning i went out there and what do you know, a big puddle under the car. i would say maybe 2 qts or so i was going to do a filter change and just drop the pan will it be ok and on a 97 isnt there a different filter then the rest.
Old Mar 11, 2013 | 01:54 PM
thepitstop2010's Avatar
thepitstop2010
Tranny fluid spreads really bad. If you leak a spot the size of a half dollar and let it sit overnight it will spread to the size of a dinner plate.
Old Mar 11, 2013 | 02:23 PM
AngryTurtle's Avatar
AngryTurtle
Im hoping it just looked like a lot.
Im hoping it wasnt really 2 quarts. Did you have to vacuum it up?
To Question about Trans fluid on the ground
