cam question
Old Jun 17, 2002 | 04:39 PM
KDubb's Avatar
KDubb
Default cam question
224/224 .581"/.581" 112' LSA
is that TOO wild for a Z06 with stock heads ?
granted, im going to get the LS1 edit and new springs and pushrods...
[Modified by KDubb, 3:01 PM 6/17/2002]
Old Jun 17, 2002 | 04:54 PM
OliverM5's Avatar
OliverM5
Active Streak: 90 Days
Default Re: cam question (KDubb)
Daily driver - too much lift.
Weekend racer - sounds just about right.
Old Jun 17, 2002 | 04:58 PM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
With proper PCM tuning it would be fine for any application... Taking off from a deadstop may require a bit of getting used to with the lump of the cam and higher idle, but I doubt you would care once you felt the power! :yesnod:
Obviously make sure you do valvesprings and pushrods at the same time as the cam install.
Old Jun 17, 2002 | 05:16 PM
COBrien's Avatar
COBrien
Cruise-In III Veteran
St. Jude Donor '06-'07-'08
I've got a 224/228 .581/.588 114 LSA cam with ported LS6 heads on my '01 coupe, and don't think it's too wild at all. The 112 will give you a bit more idle lope, though. I just did the Bloomington Gold cruise on Saturday, and spent 45 minutes idling waiting for the 749 cars in front of me to get through a stop sign, and had no trouble at all. The car is very drivable.
Good luck,
Collin
Old Jun 17, 2002 | 07:48 PM
MrEracer's Avatar
MrEracer
I'm running almost the same cam (224/224, 581/581, 113LSA) in a stock piston, stock headed '98 (see my sig.). This is a great cam for an MN6 car with no idle or drivability problems. I dyno'd the car last week (386RWHP/368RWTQ) and also ran it at the track with stock injectors and no tuning (114.25 mph)... I only have a slight rolling idle with the A/C on, I'll do a T/B hole next. I'm using the 915 spring (105# on the seat) with no problem up to 6600 rev limit... I would not recommend hard pushrods, the stock ones work great and if you ever get piston to valve contact, the pushrod will bend rather than the valve... Go for it...
Shirl :D
To cam question
