Emergency Brake pad question
Old Mar 16, 2013 | 10:37 PM
sircampsalot2's Avatar
sircampsalot2
Default Emergency Brake pad question
Does anyone have a detailed diaghram of how to change the Emergency brake pads?
I changed the brake pads and when i tried putting the rotor back on the rear it got caught on the E-brake pad and tore it...then when i pulled the rotor back off a long thin wire dropped out and i have no idea how it goes back in. I just took the whole brake pad off so i could drive it until i can figure out how to replace it, I bought some new e brake pads but it doesnt have any instructions with them and i cant find anything on the web. thanks
Old Mar 16, 2013 | 10:44 PM
bumble-z's Avatar
bumble-z
Here you go.
This will help you with that spring.
http://forums.corvetteforum.com/c5-t...y-49-95-a.html
Old Mar 16, 2013 | 11:06 PM
sircampsalot2
Originally Posted by bumble-z
Here you go.
Thank You Thank You Thank You! this will help alot I did a search andf nothing came up i dont know what i was doing wrong.
To Emergency Brake pad question
