friend c5
first of all, its not the additif !
when i roll, i hear a big clunk in the driver rear wheel
and its in the differential and it look like the shaft is square
i dont know how to tell you the feeling, but it look like something rolling and not rolling anymore, lique a square, clunk, and its continuing after.
we dont remove the differential yet.
do you have an idea ?
clutch pack ?
shaft ?
rack pinion ? gears ?
I was talking with my friend who is an Infiniti tech. He told me the G-series car have the same clunk issue and the repair is the same, lube splines and retorque the axle nut.
sounds to me like something broke inside the diff and the debris is getting caught in the gears. it could be a number of things, but I'm guessing you will need to rebuild the diff.
