Knock Sensor problem - Will this work?
Old Mar 19, 2013 | 05:11 PM
Linaki's Avatar
Linaki
Cruising
Default Knock Sensor problem - Will this work?
Hi all,
this is my first post here
I am Lina and I am from Greece. I own a 1999 C5. The mechanical mods so far are :
*Vararam intake
*Decat exhaust - cat back
The car was tuned on the dyno by experienced programmers. It gave 378hp. The car has two issues..
a. The left side of the engine, works 12:1 air/fuel ratio and the right side works at 11:1. All 8 injectors are in perfect working condition, they were measured and all render the same amount of fuel. I guess the problem exists due to the LS1 intake manifold , but I would appreciate your feedback on that matter!
b. Seems that there is a problem with the second knock sensor, and since it is not working properly, I disabled it. While browsing through internet I found MSD Knock Alert as well as Phormula KS-3 knock alert. Has anyone used them in order to prevent ping-ping-boom of the engine? Is there anything else that you have to propose for me?
Thank you so very much guys!
Lina
Old Mar 31, 2013 | 03:36 PM
Linaki's Avatar
Linaki
Cruising
Bump to the top! Need your help here!
Old Apr 3, 2013 | 10:50 AM
daytraitors's Avatar
daytraitors
Why would you disable the knock sensor instead of replacing it? The engine needs that to detect the knock and adjust timing.
Old Apr 3, 2013 | 11:07 AM
Linaki's Avatar
Linaki
Cruising
I had to disable it. I am not driving around the car, I have in the garage waiting for some parts to come. The problem is that if I don't disable it or make it "dumb" the car runs on safe mode.. I am replacing them in a couple of days hopefully!
Old Apr 3, 2013 | 01:25 PM
WKMCD's Avatar
WKMCD
The stock knock sensors work fine.
Old Apr 3, 2013 | 03:27 PM
3boystoys's Avatar
3boystoys
Really, takes an hour to replace the knock sensors, why fool around???
Old Apr 3, 2013 | 04:24 PM
Linaki's Avatar
Linaki
Cruising
Bought new knock sensors as well as harness, will change them in a couple of days!
Old Apr 3, 2013 | 08:23 PM
tom01ss's Avatar
0tom01ss
Former Vendor
do the ls2 style if adp harness, ot if your sure engine is running good. tune the codes off
Old Apr 4, 2013 | 09:01 AM
3boystoys's Avatar
3boystoys
I also changed the plastic boots in the bottom of the wells the sensors sit in, mine had a little oil in the bottom so I changed them too. Also, put RTV around the plastic covers at the top of the wells to keep water out of the sensor wells.
To Knock Sensor problem - Will this work?
