Rear wheel studs
Old Mar 20, 2013 | 10:52 AM
PaConehead's Avatar
PaConehead
Default Rear wheel studs
Is it possible to replace the rear wheel studs without pulling the hub- '04 z06?
Old Mar 20, 2013 | 11:45 AM
NukeC5's Avatar
NukeC5
You will want to pull them to properly press the old ones out and the new ones in. Otherwise your going to be smashing with a hammer from inside the wheel well "not going to be fun" and probably not have them go in correctly. Im sure it can be done.. but its not worth the risk.
Old Mar 20, 2013 | 11:50 AM
bumble-z's Avatar
bumble-z
Yes it is possible.
Personally I would remove the hub.....but here ya go
http://www.smokinvette.com/corvettef...77&postcount=3
Old Mar 20, 2013 | 11:56 AM
PaConehead's Avatar
PaConehead
Ok, thanks for confirming what I thought - puling the hub is the way to go then!!
Thanks for the quick responses - appreciate the help!!
Old Mar 21, 2013 | 08:16 AM
PaConehead's Avatar
PaConehead
Job done - followed the above advice and it went smooth.
Thanks again
To Rear wheel studs
