C5 Rear brake squeal.
Old Mar 20, 2013 | 01:30 PM
Jondamnit's Avatar
Jondamnit
Default C5 Rear brake squeal.
Hey guys... My 97 has a rear brake squeal when the brakes are applied. If I get on the brakes hard I don't hear a sound and no noise while off the brakes. I had the rotors turned last July and installed new pads. Stock brake system and replacemnet pads. I've tried bending the small tins (what ever they're called) to apply more pressure to the pad and use a bit of brake silicone to the back of the pads. Any ideas? Do the pins that the calipers ride on ever wear out? need replacing? cause noise? Thanks for looking at my Tread... Jon.
