Fuel Pump replacement write up?
Old Mar 21, 2013 | 01:46 PM
PEETYZ's Avatar
PEETYZ
Default Fuel Pump replacement write up?
I will installing a drop in walboro 400 replacement Pump and KB boost a pump for my Procharger install. Is there a write up on how to remove the old pump?
Car is a 2001 Z06.
Thanks in advance.
-Pete
Old Mar 21, 2013 | 06:39 PM
bumble-z's Avatar
bumble-z
Here ya go.
http://www.lingenfelter.com/pdf/c5fu...structions.pdf
Old Mar 22, 2013 | 09:28 AM
PEETYZ's Avatar
PEETYZ
Thank you sir! We should add this to the DIY thread.
Old Mar 23, 2013 | 05:05 PM
rbrtclk's Avatar
rbrtclk
Originally Posted by bumble-z
it appears to me that the pump will come out without removing the tanks. If so, that is something I did'nt know about Vettes Thank you,now I might replace my pump..
Old Mar 23, 2013 | 05:57 PM
bumble-z's Avatar
bumble-z
Depends which year that you have.
In the middle of the 03 model run, the factory switched over to the tank.
Old Mar 24, 2013 | 01:45 PM
rbrtclk's Avatar
rbrtclk
I've got an 02, so I guess tank removal is not necessary?
Old Mar 24, 2013 | 02:26 PM
bumble-z's Avatar
bumble-z
That's right.
Old May 24, 2013 | 12:12 PM
ucleadguitar's Avatar
ucleadguitar
Does anyone have a write up on pulling the tank to replace the pump on a 2004 Z06?
Old May 25, 2013 | 05:52 PM
boosbill's Avatar
boosbill
1st Gear
I have a 1984. It had been running fine. Did some interior work and replace the door loacks and now it won't start. thinking it might be the fuel pump. If so do I need to pull the bumper and drop the tank to replace it? Also been reading about this VATS not sure if I have it or not, but could this be the problem or just a coincidence that it won't start after replacing the door locks? I can spray ether and it starts.
Old May 25, 2013 | 06:38 PM
racebum's Avatar
racebum
thanks for the lingenfelter link
i always wondered how difficult a pump/sender swap was. thankfully i have an 02 and this looks like a saturday morning kind of job
really glad i don't have an 03-04
Old Oct 29, 2013 | 12:37 AM
Darth_Vetter's Avatar
Darth_Vetter
I have a 03 coupe with a walbro 255 that just went out. Im replacing it with 2 walbros to help my A&A setup. Are there instructions on replacing it for 03-04.
Old Oct 29, 2013 | 01:20 AM
LoneStarFRC's Avatar
LoneStarFRC
Have you checked this out? It is direct plug-n-play for late model C5s with top-loader fuel pumps. It will probably eliminate the "need" for a BAP. I would still recommend Racetronix "hot wire" direct wiring harness as well, regardless of which way you go.
http://aeromotiveinc.com/products-pa...e-stealth-kit/
Old Oct 29, 2013 | 08:05 AM
JetMechZ16's Avatar
JetMechZ16
You may want to post this in the C4 section.
Old Oct 29, 2013 | 09:56 AM
Chicago1's Avatar
Chicago1
Just did mine on my 01..Easy...here are some more pics and stuff..The second time I did it took me a total of 30-45 mins if that..
http://forums.corvetteforum.com/c5-t...cs-soon-6.html
To Fuel Pump replacement write up?
