Front Wheel Bearing Replacement
Old Mar 24, 2013 | 03:10 PM
csyvarth's Avatar
csyvarth
Default Front Wheel Bearing Replacement
This is my first post here, and hope I can get some advice. Had my C5 in to replace the climate control unit, and was told that the front wheel bearings would need replacing soon. Total cost, $869.00. I did some research, and found that Timken are the bearings of choice, and found them on ebay for $360. Is it reasonable to pay $500 labor? Is the job really that big? Any advice would be appreciated. The following is the description from the ebay add. Thanks, Charl
: TIMKEN Chevy Corvette C5 C6 XLR Front Wheel Hubs & Bearings 5 Lug Pair Set
Order by Noon EST and this part ships today!
Always Free Shipping with your AM-AutoParts orders.
Lowest price on brand new, in-the-box auto parts.
Detailed Applications
TIMKEN WHEEL BEARING & HUB ASSEMBLIES: 513139
Specifications:
Brand New Timken Wheel Bearing & Hub Assemblies
Comes as a PAIR
Fits both LH (Driver Side) & RH (Passenger Side) FRONT
3 Bolt Flanges
Fit 5 Lug Wheels
Replaces dealer part number: 88967287
Direct replacements
Built to strict quality control standards
Brand NEW fitting for the following years and models:
2004-08 Cadillac XLR Front Wheel Bearing & Hub Assembly Pair (Timken)
2006-07 Cadillac XLR-V Front Wheel Bearing & Hub Assembly Pair (Timken)
Old Mar 24, 2013 | 04:00 PM
alextz's Avatar
alextz
Thats highway robbery for labor.
I can replace the c5 front hubs from on the car on the ground, in about 1.5 hours. pretty easy if you have the GM ball joint separator so as to not damage the lower ball joint boot.
