Gutting the Pups
Old Jun 18, 2002 | 07:13 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Default Gutting the Pups
I want to gut the Pre-Cats on my 2001 coupe. Can I do this while the car is on a set of ramps?
Bob
Old Jun 18, 2002 | 07:22 PM
Mike Mercury's Avatar
Mike Mercury
Default Re: Gutting the Pups (16Again)
Yes; all you need do is unbolt the H pipe assy and slide it out from underneath the car.
It's tight underneath, so I had my fronts on my 10" ramps, and the rear tires on 4" risers made otu of 4x4's.
If you haven't yet, look here for details:
mikemercury.home.att.net/precats.htm
[Modified by Mike Mercury, 6:29 PM 6/18/2002]
Old Jun 18, 2002 | 07:23 PM
VNAMVET's Avatar
VNAMVET
Veteran: Marine Corps
It would be much easier if you were on a lift. I removed my 2 cats from my 2000 Black Bitch Coupe and used a pair of O2 Simms ($89). Lost bottom torque and gained top end "pull"............. :yesnod:
Old Jun 18, 2002 | 09:36 PM
dads01dream's Avatar
dads01dream
Default Re: Gutting the Pups (BLUECOUPE)
So, if you gut the pups you have to use O2 eliminators??
Old Jun 18, 2002 | 09:53 PM
16Again's Avatar
16Again
Default Re: Gutting the Pups (dads01dream)
No, I will only be gutting the pre-cats. The main cats will remain on and functional.
Bob
Old Jun 18, 2002 | 10:08 PM
C5 Tweaker's Avatar
C5 Tweaker
Take care not to plug up the main cats with debris - thus countering what you are trying to accomplish.
Wet the catalyst and insulation with a hose before chiseling. I used a shop vac output connected to the muffler end to blow particles away from the main cats. Use a respriator, particularly if you use forced air.
FYI - I later removed my main cats. Big mistake - only 2-3 hp on a 425RWHP vehicle, lots of smell, and lots of resonance.
Old Jun 18, 2002 | 10:11 PM
16Again's Avatar
16Again
Default Re: Gutting the Pups (C5 Tweaker)
C5 Tweaker, I also had the cats removed at one time. My better half didn't like the smell so I put them back in. Thanks for the info. :cheers:
Bob
To Gutting the Pups
