Screw in the runflat...
Old Jun 19, 2002 | 12:20 AM
gaww's Avatar
gaww
Default Screw in the runflat...
Driving with the top down today and noticed a rhythmic clicking sound coming from the rear right tire. Knew right away exactly what had happened. I look at my rear runcrap and see a hexnut screw nicely embedded in the middle of my tire. My question is what is the best way to fix it? Should i plug it myself or should i bring it to a place like Just Tires and have them patch it up? I dont mind having them doing it but I'm always afraid of some careless dumass that will mess up and scratch my wheel when they take it off the car.
Also random question: what is the best way to get maximum lowering on my c5 so that there is about an inch gap? Not interested in cutting any bushings so maybe coilovers are the only choice?
Thanks for all the help.
Old Jun 19, 2002 | 02:56 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: Screw in the runflat... (gaww)
I would go to a shop with a qualified EMT repair person.
Old Jun 19, 2002 | 03:06 AM
Blackjetvette97's Avatar
Blackjetvette97
Default Re: Screw in the runflat... (wallstAL)
Hi Gaww,
Let's see here.....I have had mine patched($65 bucks) due to a :mad screw. I know you will lose the speed rating because of the repair. It is a law the repair place must advise you of. I believe your tire will be speed rated at 112 MPH or something like that. Of course, in reality, it CAN go faster than that, but they just need to cover their Azzez! As far as the shop that does it, make sure they have a qualified tech who can handle tire pressure sensors or you'll be paying a LOT of money just for a simple screw repair(in that you'll be buyin' new TPS's) Mine cost that much due to the TPS devices on each tire. I'm sure they just use that as an excuse to rip people off! Also, make sure they have a tire removal machine that grabs the rim from the inside, so as not to scratch your rims! HTH
Steve
Old Jun 19, 2002 | 07:46 AM
TRR's Avatar
TRR
Default Re: Screw in the runflat... (Blackjetvette97)
Discount Tire will fix it for free. Also, if the tire is ruined, Goodyear will take care of it for the first year.
MRR
To Screw in the runflat...
