Transmission problems 6 speed stuck in 4th
Old Dec 22, 2022 | 02:22 PM
jkevallen's Avatar
jkevallen
6th Gear
It has been a long road. Pulled the transmission, took apart, found broken piece within 3-4 shift fork. Reassembled, drove and quickly found a new problem like yours, it grinds only going from 5th to 4th. Took apart again and should have back together by tomorrow. Will let you know...
Old Apr 16, 2025 | 03:11 PM
Lifsgrt's Avatar
Lifsgrt
Yep, old thread. Just as valid today as it was then, as all this happened in the last 3 months.
I have a 2000 base model with 184,000 miles. I drove it at Sebring International and got stuck in 4th, but it would come out of 4th when it cooled down.
I drove my 2002 Z06 22,000 mile car at Sebring International and it locked in 4th hard. Shifter will not budge, solidly locked in 4th. Drove it 2 hours home. This car, in certain places on track, would have difficulty going into 4th and 6th prior to the trans getting stuck in 4th.
I have yet another 2002 Z06 that would have the same issues going into gear in the same spots on track at Sebring, but never locked into a gear.
Seems like this should be in the "things to plan to fix on a C5 eventually" just as a heads up. I do appreciate all the tech expertise located on this forum, so thanks for that!
