What Spark Plugs you running?
Old Apr 5, 2013 | 10:43 PM
sircampsalot2's Avatar
sircampsalot2
Default What Spark Plugs you running?
I'm going to go ahead and change my plugs tomorrow, what brand would you buy?
Old Apr 5, 2013 | 11:15 PM
Sideswipe505's Avatar
Sideswipe505
Mods? Any kind of nitrous or forced induction, step down to a colder plug. If the car is stock, get stock plugs.
Old Apr 5, 2013 | 11:16 PM
thepitstop2010's Avatar
thepitstop2010
Ngk tr55
Old Apr 5, 2013 | 11:24 PM
racebum's Avatar
racebum
delco 41-110 or ngk tr5ix
there was a service bulletin that replaced thet tr55 with the tr5
the only difference is the 41-110 and tr5 are gapped at .040 not .050, long story short larger gaps are more likely to detonate but usually make more power. smaller is the reverse
Old Apr 5, 2013 | 11:43 PM
sircampsalot2
Is iridium better than platnum or vise versa? Ive red that plugs with silver in them are the best but i havent seen any with silver in them
Old Apr 5, 2013 | 11:44 PM
racebum's Avatar
racebum
copper is the best conductor of electricity but it also wears the fastest. if you change your plugs every 15k miles use copper. if you want to go 50k miles or even 100k use iridium
Old Apr 6, 2013 | 12:56 AM
NukeC5's Avatar
NukeC5
The idea behind iridium is that they last a long time. I use copper as I change them often for best performance. Im using the TR55's. Car runs great with them and as stated, the larger gap you can get away with will increase power.
Old Apr 6, 2013 | 01:36 AM
sircampsalot2
ok thanks guys
Old Apr 9, 2013 | 06:30 PM
silversport's Avatar
silversport
Aren't the iridium and platinum only tipped in those metals with copper cores???
I currently have AC Delco RapidFire double platinums...
Bill
Old Apr 10, 2013 | 12:31 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
Bill
yes
Old Apr 10, 2013 | 12:36 AM
C5Natie's Avatar
C5Natie
Actually silver is but there are no silver plugs since they would be super expensive. Copper is the way to go for performance and it lasts much longer then 15k miles. My copper Autolite 103's after 30k mi still looked good. I checked the gap every 10-15k mi.
Old Apr 10, 2013 | 05:33 PM
1morelap's Avatar
1morelap
Isn't an Autolite 103 heat range too cold for stock motor?
Old Apr 10, 2013 | 06:21 PM
racebum's Avatar
racebum
depends on how you drive. my cherokee lives 30+k miles on coppers too, my old autocross integra would kill copper plugs in 12-15k miles.
high rpm track time seems to really shorten plug life
Old Apr 10, 2013 | 06:30 PM
C5Natie's Avatar
C5Natie
For stock, yes. Theyre are around the same temp range as ngk tr6. Ive had good luck with them on motors making 450-500rwhp. Especially in the summer time when youre a bit more prone to detonation.
Old Apr 11, 2013 | 08:18 AM
Bill McCassey's Avatar
Bill McCassey
Originally Posted by thepitstop2010
Ngk tr55
Old Apr 11, 2013 | 10:36 AM
DARRYLZO6's Avatar
DARRYLZO6
Originally Posted by printmanjackson
yes
Same here.
Old Apr 11, 2013 | 11:40 AM
SaberD's Avatar
SaberD
Does the number of outer electrodes matter at all? I'm running the acdelco irridiums, but there are plenty of plugs out there with 2-4 outer electrodes. I never understood this. You see the platinums with 4 electrodes, but I've never seen irridiums with 4. What gives? I know it increases longevity of the outer electrodes, but why don't they do it for irridiums?
To What Spark Plugs you running?
Old Apr 11, 2013 | 06:40 PM
NukeC5's Avatar
NukeC5
Electricity will always jump to the nearest electrode. The purpose of multiple electrodes is that when one wears, the next that becomes closest will be used to complete the circuit. So yes, its a longevity thing. Nothing performance about it. In fact, it can hurt it if you consider the idea behind gauging spark plugs.
In an iridium plug, the tip is so small that only one electrode can be lead to it. The design doesn't allow for multiple electrodes.
If longevity is your goal, I'd choose iridium over a multiple electrode plug any day. But IMO copper plugs are still the best and just need changed every 30-40K miles.
Old Apr 11, 2013 | 06:52 PM
Baldfart's Avatar
Baldfart
Ac 41-110.
Old Apr 11, 2013 | 08:08 PM
silversport
yes
Thanks...so what's the big complaint of platinum or iridium???...they're all copper plugs but the platinum and iridium tipped will last longer...
Bill
