Best DIY balljoint tool for C5 upper?
I was trying to lower my front (2001 Z06)and was doing the bushing trim which required removing the bolts to get access. In doing so, I tried to remove the pass upper balljoint nut and it seized at the end of the threads (corrosion on the threads-even used PB Blaster before moving the nut) and the allen hole stripped out on me!!
Had to cut the shaft to get the upper control free of the seized bbj and steering knuckle.I now need a new balljoint, going Raybestos from Rock Auto, and some advice on what tool might work good for a DIY garage job for the removal and install. Ive seen Kent-Moore J-42188-B recommended, but this looks like a removal only. I would also like to install it on my own in the garage without any further dismantling.
Ive done lots of searching but no clear answer on this.
Appreciate any replies.
B.
It's also recommended to heat the aluminum spindle on both the removal and install to give a little extra room. I used a propane torch. Otherwise, material can be removed and the press fit won't be as tight as necessary. It also helps to keep the new balljoint in the freezer overnight prior to install.
It's not a hard job - but you'll need to take the spindle off the car to hold it securely. I used a bench vise.
Good luck!
I frozen the ball joint over night and heated the A frame with a heat gun. It popped out using the heat and a Ball Joint Press from Advance Auto. Used heat and the press to get it back in. I used my impact gun on the press and it made quick work.
I found this method in the Auto Cross section I believe. There are plenty of write ups and ball joint recommendations there for the C5.
Im planning to use the Kent-Moore J-42188-B to remove with some heat and the C-clamp installer tool with heat on the arms and balljoint from the freezer. This will be with the steering knuckle on the car.
