Oil pressure
Old Apr 7, 2013 | 10:23 PM
robert1989's Avatar
robert1989
Default Oil pressure
Ok, I have a 1998 C5 A4 with 154,000 miles on it.
I got it 5 years ago as my every day car and put 84k of those miles on it.
Since I've had It the oil pressure has been between 14-15 at idle after warmed up.
Mods
X-pipe, glass pack exhaust
Ram air intake
Installed oil catch can a few days ago
Positive history
Oil changed under every 5,000 miles either Valvoline or Mobile 1 5W-30
Runs like some kind of savage animal pulls like a freight train and starts every time I turn the key.
Some negative history.
I have and always will beat the **** out of it.
Engine sucked up some water once in a deep poodle changed oil twice no problems after. (Uhaul parking lot in Hempstead New York)
Shortly after I would be sitting at a light and oil pressure would go to 0 DIC would warn me and I would kill the engine. I would turn the engine back on and oil pressure would go back to normal. This may have happened 5 times at the most.
It stalled twice since I've owned it while idling just after start up, completely irrelevant.
This is where I think I may have found the cause of the problem. It always had a funny smell at wide open throttle. Sulfur smell maybe oil burning? Last year it started to leak oil out of the rear main seal? Maybe half a quart? between oil changes. Never seen oil drip from the bell housing area/rear oil pan area just coated with oil.
So how do I know if my oil pressure sending unit is bad/loose. If it is loose would the oil pressure be low? If it is bad would it leak?
Old Apr 11, 2013 | 09:01 PM
robert1989's Avatar
robert1989
anyone?
Old Apr 11, 2013 | 09:17 PM
C5Natie's Avatar
C5Natie
Rob, there have been many threads on this issue especially in the last couple months. You may get a few different answers but truth is that the car should not be doing what you said it has, as in the loss of oil pressure. Personally I feel anything under 20psi is a bit low and 15 or less would have me worried. Usually oil pressure sender units fail reading high but have known to fail reading either way. I think, like its been suggested in other threads, the best thing to do is to hook up a mechanical gauge and monitor the oil pressure under various temps and rpms. That should tell you whether its a mechanical or electrical (sender) issues. Then you can go from there.
Old Feb 27, 2022 | 10:28 AM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
edit: dang “related threads” caught me again when downscrolling to bottom of thread. my apologies. its a decent feature, but catches even the dumbest of us sometimes.
Old Feb 27, 2022 | 11:32 PM
jim993's Avatar
jim993
04 /07 2013 - delete.
To Oil pressure
