differential case - hex nut size??
Old Jun 19, 2002 | 05:55 PM
broncos872's Avatar
broncos872
Cruising
Default differential case - hex nut size??
was going to change my rear differential lube, but don't want to get started until i know what size the hex nut is on both the fill and drain plugs. i was going to use mobil 1 synthetic lube, but was also wondering if it needs the limited slip additive or not. any help for the lube change would be appreciated. :smash:
Old Jun 19, 2002 | 06:44 PM
c4c5specialist's Avatar
c4c5specialist
Cruise-In II Veteran
Default Re: differential case - hex nut size?? (broncos872)
Hi there,
10 mm allen socket on the plugs, and yes, you will need the friction modifier, without exception.
Besttoyou, c4c5 :chevy
Old Jun 19, 2002 | 08:11 PM
Mike Mercury's Avatar
Mike Mercury
Default Re: differential case - hex nut size?? (c4c5specialist)
if you don't have a metric wrench, I think a 3/8 fits it also.
To differential case - hex nut size??
