Fog light install - have questions
Old Jun 19, 2002 | 06:08 PM
bdavies's Avatar
bdavies
Default Fog light install - have questions
I ordered my car w/o foglights and ended up buying a set recently. I was going to start assembling the parts required so that I can put them in one of these weekends. I figured at a minimum, the following would be needed:
L & R foglights w/ bulbs (have these already)
OEM mounting bracket or custom fabbed bracket (my neighbor has a machine shop in his garage :) )
Dash hatch release button assembly with foglight switch (figured I'd look on the for sale section here or buy at dealer)
My questions are:
1) Do I need to add a relay and/or fuse or are these installed already?
2) I hear mention of the need to buy or add a wiring harness. But if I look down the opening between the open hood and front facia, I see what looks like an unused electrical connector in the viscinity of the passenger-side foglamp location. I had assumed this was the foglight connection and was already a part of the installed harness. Is this a bad assumption?
I did a search through all the posts and didn't find answers to these questions. If they have and I missed them, please let me know.
TIA,
Ben
Old Jun 19, 2002 | 08:54 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Default Re: Fog light install - have questions (bdavies)
I as you are looking into doing the same thing. I was told the wiring is there and all that needs to be done is plug in the wire under the hood and change out the dash switch. Guess we will find out soon. :cheers:
Bob
Old Jun 19, 2002 | 10:45 PM
bdavies's Avatar
bdavies
Default Re: Fog light install - have questions (16Again)
Bob, thanks for the reply. I hope you're right because I don't feel like stringing any wires from the engine compartment to the back of the dash. If that's the case, my daily driver Ford Ranger might get a new set of foglights :yesnod:
Old Jun 20, 2002 | 12:11 AM
Saving41's Avatar
Saving41
I have been wondering the same thing myself for my 01 Z06. I would be interested in what you find out. Pictures? :D
Old Jun 20, 2002 | 12:44 AM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
From the C5 tech tips page:
https://www.corvetteforum.com/techti...=130&TopicID=1
Old Jun 20, 2002 | 05:01 AM
Speeder's Avatar
Speeder
Are these factory lights you're installing? The brackets comes with the lights as an assembly.
The fuse and relay are already installed on the car.
If the connector has two wires and one of them is purple, then that should be the right one. I would verify it by connecting a test light to the wire and turning on the foglight switch just to be sure.
Old Jun 20, 2002 | 01:09 PM
Saving41's Avatar
Saving41
Default Re: Fog light install - have questions (Speeder)
Thanks for the tips!
Old Jun 20, 2002 | 03:52 PM
bdavies's Avatar
bdavies
Thanks for the info. I'll check the color of the wire this weekend.
Yes they are factory fog lights, but there are take-offs that I bought without brackets.
Old Jun 20, 2002 | 03:58 PM
bdavies's Avatar
bdavies
Default Re: Fog light install - have questions (Saving41)
I'll take pictures of what I end up doing.
-Ben
Old Jun 21, 2002 | 12:30 AM
Saving41's Avatar
Saving41
Thanks Ben,
I really looked around for the wiring harness, but haven't found it yet. Any pictures would be great! :cool:
To Fog light install - have questions
