2000 C5 Starting issue
Old Apr 9, 2013 | 02:07 PM
Sids04's Avatar
Sids04
Default 2000 C5 Starting issue
My 2000 M6 FRC on ocassion makes the dreaded bad ground 'click' when trying to start it, ie the key turned to the start position and click. All guages etc light up and function. When this occurs the DIC voltage reads like 11.7 volts with the key in the ON position. When I follow Bill's ignition switch test procedure the voltage to all of the fuses reads the same with the key in the start postiton (11.7). With the switch in the off position it reads 12.6 volts, this is via the DIC and a volt meter.
I have cleaned all of the under hood grounds and the battery connections are tight. I had the connection to the starter cleaned when I had it inspected last week. The battery reads 12 + volts when the key is off. The Altenator is working, I think ? When normal it reads
between 14.2 to 14.5 volts once again via the DIC and a volt meter. After the starter connection was cleaned it was fine for a week.
Today It did it again .. This time the voltage read 12.2 volts. I push started it and the volts on the DIC after it started stayed below 14(13.9), as opposed to the normal 14.2-14.5..
Switch ? Solenoid ? Altenator ?
Old Apr 9, 2013 | 03:31 PM
Sids04's Avatar
Sids04
Originally Posted by 8VETTE7
Could be a bad solenoid or a bad battery.
Have you pulled the battery and had it load tested?
Yes I had it load tested... I forgot to mention that..
Old Apr 9, 2013 | 03:49 PM
RonSSNova's Avatar
RonSSNova
Solenoid would be my guess. I "think" you can buy one.
Ron
Old Apr 10, 2013 | 05:51 AM
Sids04's Avatar
Sids04
I am going to verify that they did clean the terminals on the starter.. If need be I will just replace the starter..
Old Apr 10, 2013 | 01:39 PM
tacman's Avatar
tacman
St. Jude Donor '13
Is it a "dead battery click" or are you hearing the solenoid engage? Will it start after several tries?
Old Apr 10, 2013 | 02:39 PM
Sids04's Avatar
Sids04
Sometimes it does.. There is no predictable patern..
Old Apr 10, 2013 | 04:15 PM
tacman's Avatar
tacman
St. Jude Donor '13
Default Starting Issue
Mine does the same thing. Probably a bad brush or commutator section in the starter where brush doesn't contact; depends on how the starter armature is clocked when the car stops. Turning the key several times finally bumps the starter to a sweet spot where it will start.
New starter going in this week.
Old Apr 10, 2013 | 04:46 PM
Sids04's Avatar
Sids04
There is no sweet spot now..
Old Apr 11, 2013 | 01:02 PM
Sids04's Avatar
Sids04
The starter was cracked .. I will post pics later
Old Apr 11, 2013 | 03:53 PM
Sids04's Avatar
Sids04
Here it is.. Not electrical..
To 2000 C5 Starting issue
