Need Help Emergency Flasher
Old Apr 9, 2013 | 06:41 PM
G Atkins's Avatar
G Atkins
5th Gear
Default Need Help Emergency Flasher
I replaced flasher on my 2000 C5 I thought everything was good until I hooked up battery and found emergency flasher wouldn't turn off. I replaced with oem part had no problems thanks to forum for posts that helped. When I push in emergency flasher they work fine indicator light comes on when I push to release indicator light goes off however they continue to flash. need help at wits end. I find this forum very helpful if it wasn't for this site I doubt if I could afford this corvette.
Old Apr 9, 2013 | 08:24 PM
UDRIVESLOW's Avatar
UDRIVESLOW
what was the problem with the old hazard switch/flasher? was it doing the same thing?
Old Apr 9, 2013 | 11:09 PM
G Atkins's Avatar
G Atkins
5th Gear
They were intermittent. By pressing the emergency flasher they would work for a short time then same problem. I found the problem parts house gave me wrong part number I have replaced with correct one they work fine. Thanks
To Need Help Emergency Flasher
