8.1L Suburban engine
Old Jun 19, 2002 | 09:05 PM
wsaracen's Avatar
wsaracen
Default 8.1L Suburban engine
I saw a while ago there was a guy in a magazine that put a 8.1L suburban engine in a corvette. Why hasnt any tuners tried starting out with this engine for tons of torque and maybe with a blower break the 8 second barrier. What are anyone's ideas.
Old Jun 19, 2002 | 09:08 PM
Ram Air Tony's Avatar
Ram Air Tony
Default Re: 8.1L Suburban engine (wsaracen)
that motor is a BIG heavy mo fo...thought about gettin one for my truck and moddin it up......that would be a GREAT SC motor as it has like 9:1 compression :yesnod:
thanks
Old Jun 19, 2002 | 09:16 PM
wsaracen's Avatar
wsaracen
Default Re: 8.1L Suburban engine (Ram Air Tony)
couldn't the amount of power capablilities outweigh the weight. Im sure it would be great for the dragstrip.
The article is VETTE March 2002
Old Jun 19, 2002 | 09:23 PM
NassyVette's Avatar
NassyVette
ZL1 Camaro? Doesn't that have an 8L engine? It's in the 9's NA.
Old Jun 19, 2002 | 09:24 PM
wsaracen's Avatar
wsaracen
Default Re: 8.1L Suburban engine (NassyVette)
good point. I have no idea about the zl1 camaro though.
Old Jun 19, 2002 | 09:36 PM
NassyVette's Avatar
NassyVette
It's an 8.4L 770 HP through full exhaust. Check it out http://www.zlx.com/camaro/zl1.htm
Old Jun 19, 2002 | 10:07 PM
Miles in Michigan's Avatar
Miles in Michigan
It wouldn't work too well. All the other new GM truck V8s are LS1 based, so parts swap in and out relatively easily (including the iron block from the 6.0). The 8L on the other hand has NOTHING in common with the LS1. It's also a cast iron block, and cast iron (and lousy flowing) heads. It'll weigh a lot, and not make any more power than a LS1-based 7.0 liter, without a LOT of work.
<edited to add, the car in the link has an aluminum 8.4L block. don't think you can buy one of those over the counter :))
[Modified by Miles in Michigan, 8:16 PM 6/19/2002]
Old Jun 20, 2002 | 01:05 AM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
The 8.1 liter truck motor is nothing more than a Traditional Big Block Rat motor. In fact its nothing more than a stroked 454 Big Block.
Cast Iron Block, Cast Iron Heads
340 HP / 455 TQ
Its displacement is 496 cubic inches:
4.25 Bore x 4.37 Stroke
You would have to butcher the C5 engine bay to get it to work.
Not to mention the 8.1 liter is made to work with the allison transmission.
Old Jun 20, 2002 | 02:02 AM
wsaracen's Avatar
wsaracen
Default Re: 8.1L Suburban engine (kewlbrz)
dont get me wrong, i would never do this. i was just reading my old magazines. vette march 2002 has someone that put this engine into a c5. i thought it was pretty cool. i guess the aluminum 7L would be the way to go although 8.1L would be 8 cubic inches bigger then the viper engine
Old Jun 20, 2002 | 02:16 AM
kewlbrz's Avatar
kewlbrz
you can get to 471 cubic inches with a C5R block using a lunati 4.25 crank, and a 4.20 bore. Definatly never be able to breath as good as a traditional big block chevy can, but it would be plenty of displacement! :yesnod:
Old Jun 20, 2002 | 11:13 AM
tbyrne's Avatar
tbyrne
From: Westport, MA. www.tbyrnemotorsports.com - 1-877-4-TBYRNE
St. Jude Donor '06-'07
The 8.1 is a BIG motor that would be a tight fit and require alot of fabrication. The above pitures show the 8.1 that is in our 2002 Suburban topped with a Whipple supercharger/intercooler.
Tom
[Modified by tbyrne, 11:26 PM 6/20/2002]
Old Jun 20, 2002 | 11:28 AM
Shinobi'sZ's Avatar
Shinobi'sZ
Default Re: 8.1L Suburban engine (tbyrne)
You mean a Whipple S/C right?? Nice setup regardless.
Old Jun 20, 2002 | 04:01 PM
davidmax's Avatar
davidmax
Default Re: 8.1L Suburban engine (Shinobi's97)
There are so many tricks available forced air/proper tuning/stroker kits etc....Weve found the Tqe. in a N/A 422 stroker with forced air is = to yhat of the rat with out fabrication costs,can be put back to stock and parts investments partially recouped.Why bother with all the 21st century smarts lets all go for blown strokers .A ROUND FOR EVERYONE TROYS TREAT!!!Dave
Old Jun 20, 2002 | 11:42 PM
FreddyG's Avatar
FreddyG
Default Re: 8.1L Suburban engine (davidmax)
:cheers: to TROY!!!!!! Where do we sign up?
Old Jun 21, 2002 | 12:30 AM
tbyrne's Avatar
tbyrne
Shinobi's97: Thanks for pointing that our. The fingers didn't type what the brain was thinking :)
Tom
Old Jun 21, 2002 | 01:58 AM
66ImpalaLT1's Avatar
66ImpalaLT1
A properly done set of C5R heads on a 471 CI short block would be a better all around engine than a big block, as long as it has the right intake manifold.
Eric
Old Jun 21, 2002 | 09:49 AM
tt427pacecar's Avatar
tt427pacecar
St. Jude Donor '05-'06-'07
Not quite true. The 496 is reverse cooled like the LT1's were. This means that the heads are different, none of the aftermarket big block heads will fit. I believe they also changed the firing order, which rules out all the aftermarket cams.
These changes severely limit what can be done with the aftermarket big block parts currently in production. :cry
To 8.1L Suburban engine
Old Jun 21, 2002 | 11:55 AM
kewlbrz's Avatar
kewlbrz
Default Re: 8.1L Suburban engine (449pacecar)
449pacecar, thanks for the clarification. :cheers: My point was to put the focues on the fundamental characterisics though. also FWIW, GM sells a 415hp/490 ft./lb 8.1 model for marine use.
66impalaLT1: I would disagree, at least with respect to a traditional big blocks potential. The heads for a bigblock are just too much better for flow. In a C5 a super stroker would be the better choice for feasability and fit. Regarding the C5-R heads. They are 38 cc chambers (Thats a small chamber for a street car), and have a valve angle at 11 (15 on LS1/LS6) degrees. They have a higher intake port runner than LS1 production heads and stock exhaust ports other than that, they arnt much different than an LS1/LS6 heads (somewhere in between). At least that is my understanding.
[Modified by kewlbrz, 9:57 AM 6/21/2002]
Old Jun 21, 2002 | 11:14 PM
HP-GURU's Avatar
HP-GURU
Big Blocks have larger bore spacing, larger bores, and bigger valves.
I've seen the BBF heads flowing 500CFM or so and 400CFM by .500". on the intake side.
Small block heads won't do this.
Old Jun 22, 2002 | 06:14 AM
silversport's Avatar
silversport
Default Re: 8.1L Suburban engine (HP-GURU)
Do you know how that car would handle with that boat anchor out front??? :rolleyes: :eek: :crazy: :yesnod: :seeya
