harmonic balancer bolt replacement....
Old Apr 17, 2013 | 05:30 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by williamb81
Derek, I would have bought yours but 5 mins before your post i ordered the Powerbond from texas speed along with the A&A pinning kit.
Thanks again for everyones suggestions/help minus 1999 trc's of course.
He told you the truth, you just don't want to hear it. Swapping a damper on these cars, due to having to remove the rack, etc, tells me ONE important thing..... do it right and do it ONCE!
Old Apr 18, 2013 | 07:05 AM
reath1's Avatar
reath1
I read the dozens of threads on this before doing mine. Decided to do it once and be done. Installed the ATI balancer and pinned it using their kit also. Very pricey but doing it right once is cheaper in the long run to me. Used a torque wrench that went to 250 lbs. I didn't and still don't understand using never-seize on the bolt instead of loctite but I did. Not sure exactly what I torqued it to but I can tell you that after I got the click at 240 I gave it an extra "UUUUMMMPPHHH" on the cheater bar. To be honest I would say it's around 260-270 lbs. I felt it closing the gap on the engine cradle on the passengers side. That was about 2500 miles ago and still spinning true with no problems.
Good luck.
Old Apr 18, 2013 | 05:46 PM
leadfoot4's Avatar
leadfoot4
Good luck.
IIRC, the directions that ATI printed out said "use a light coating of never seize on the crank snout". This is so the hub slides on the crank easier. You then use red Loctite on the bolt......
If you used never seize on the threads of the bolt, torqued it to 240 lb/ft, then gave it a little more, you're PROBABLY torqued to 280-290 lb/ft, as never seize reduces friction on the threads, therefore reduces the required torque to achieve the same clamping force.
Old Apr 18, 2013 | 06:18 PM
kmetros's Avatar
kmetros
It's a fact. That's why I posted the link to my same problem along with the information on the tool to keep the crank from moving. 200 Ft/lbs plus as much as I could hog on it won't cut it. The 1" bar on this tool was bowing while we held the crank and pulled on the torque wrench to get it to click off at 240.
Old Apr 19, 2013 | 12:13 PM
reath1's Avatar
reath1
Just read over the instructions and you are correct. A little depressing but yea, the never seize would have reduced friction so it probably is torqued up near 300 lbs. Hope it holds...in my way of thinking since I pinned it there won't be much if any force on the bolt to back it out so hopefully I will be ok.
Old Apr 19, 2013 | 04:35 PM
nitrouspaul's Avatar
nitrouspaul
can someone just post a quick remove the rack proceedure here for me my bolt is loose too and the rack wont move up enough for me to get a socket on and retighten the loose bolt and i am trying not to lower the cradle as i just had the alignment done but the rack will not slide it gets stuck between the frame
Old Apr 19, 2013 | 04:46 PM
williamb81's Avatar
williamb81
after you unbolt the rack, you should be able to move it out the way without lowering the cradle by moving it to the passenger side not the drivers side. GL
Old Apr 19, 2013 | 05:18 PM
kmetros's Avatar
kmetros
You need to remove the 4? bolts holding the ABS bracket in place. From memory this bracket goes around the pinion and with it in place you can't move the rack out the side of the car. With this bracket unbolted and zip tied up and out of the way as far as you can get it, you should be able to slide the rack outside the passenger side wheel well. I didn't need to loosen/drop the rack....but then I already had a bunch of other stuff off of the front of my engine (water pump, alternator, etc) for my cam install.
Old Apr 19, 2013 | 07:50 PM
nitrouspaul
already done wont go thru
Old Apr 20, 2013 | 02:38 AM
williamb81's Avatar
williamb81
Just got done with mine. Took the rack out the drivers side after dropping the cradle about half an inch.
Old Apr 20, 2013 | 11:02 AM
nitrouspaul
one guy says passenger side one guy says drivers side whew??
Old Apr 20, 2013 | 11:23 AM
reath1's Avatar
reath1
If you plan on sliding the rack out, you will have to drop the cradle and I really don't see the rack going out the passengers side. I also don't think you can get to the bolt properly with the rack in the car. Lowering the cradle
literally adds about 20 minutes to the job both lowering and raising. Don't see any reason why not to.
Old Apr 20, 2013 | 02:15 PM
  #33
feeder82's Avatar
feeder82
I didn't drop the cradle when I removed my rack, I slid it up the pass. side first then down and out the drivers side
Old Apr 20, 2013 | 03:54 PM
  #34
nitrouspaul
Just paid 200 bucks for a 4 wheel alignment at aruns and was wondering if lowering the cradle screws up the alignment from front to rear wheels
Old Apr 20, 2013 | 04:34 PM
  #35
reath1's Avatar
reath1
I am not an alignment guy but I seriously don't see how it could effect the alignment at all. You are removing the tie rod. Not turning any threads on it and the cradle comes straight down and straight up. No adjustment there at all so it really can't throw anything out of whack.
Oh, and if you paid $200 for an alignment...they ran that one up you hard and dry. You should be walking funny. Should have been no more than $100. I think I pay $89.
Old Apr 20, 2013 | 07:18 PM
  #36
lionelhutz's Avatar
lionelhutz
There are alignment dowels to keep it in place.
$200 was expensive. I paid $100 at a GM dealership - Bennett in Cambridge and they have the rack setup so that a lowered Vette can drive right on and they will set it up right or even to your specs.
Old Apr 21, 2013 | 08:53 AM
  #37
reath1's Avatar
reath1
Correct. I forgot about the dowels. Has to go straight back up there. But again, you got hammered on that alignment. I would hope that would have come with a lifetime warranty or something.
Old Apr 22, 2013 | 10:11 AM
  #38
williamb81's Avatar
williamb81
Got my alignment done sat and it was 89.00 for 4 wheel. Did my first autocross sunday in my frc and loved it. Would have loved it way more with some A6s ~
