Need Help.....DIC Says RF Tire Is Flat
Old Jun 20, 2002 | 11:26 AM
G Man's Avatar
G Man
Default Need Help.....DIC Says RF Tire Is Flat
On the way home from the airport last night, I encountered this message three times. Each time I checked the tire pressure on the DIC, and stopped to physically check the tire with a tire gauge. The tire is holding at 36lbs. with no variation. As a reference, it is occuring on my '98, and I am running 18"chrome ZO6's, with MXX3 non-runflat tires. I have had this combo fo about 9 months with no problems. Any ideas????? :confused:
Old Jun 20, 2002 | 11:32 AM
NEED FOR SPEED's Avatar
NEED FOR SPEED
CI 3-4-5-6-7-8-9-10 Vet
St. Jude Donor '07
Default Re: Need Help.....DIC Says RF Tire Is Flat (G Man)
It could be a bad sensor. I would try the relearn procedure first to see if that helps. Roger
Old Jun 20, 2002 | 11:52 AM
C5 Frederik's Avatar
C5 Frederik
with 98 % your sensor is dead. Went through this many times.
Frederik
Old Jun 20, 2002 | 03:27 PM
davidmax's Avatar
davidmax
Call Nate I think we have some take off sensors in the shop and then go see Discount tire.Dave
Old Jun 20, 2002 | 08:50 PM
Stilcrazee's Avatar
Stilcrazee
Default Re: Need Help.....DIC Says RF Tire Is Flat (NEED FOR SPEED)
Is the relearn proceedure posted somewhere? I have a 98 with stock chromes and under 6k miles, tire pressure is real slow coming up on dash or 1 does and 1 doesn't for a while. Or is it in the (seldom read) owner's manual?
Old Jun 20, 2002 | 09:08 PM
Richin Chicago's Avatar
Richin Chicago
Default Re: Need Help.....DIC Says RF Tire Is Flat (Stilcrazee)
Is it slow to come up while your are in motion? This is a transducer so it won't read until you hit a certain speed.
Old Jun 20, 2002 | 09:44 PM
brandonsvett
My 98 coupe does exactly the same thing but it is the LR tire instead. I am also getting the service tire monitoring system warning. I posted a letter on this site with the same concerns as you and everyone says i should try the tire relearning thing first. As soon as i find a big magnet i will try it. I have found this procedure on the net under this link--- http://www.rivercitiescorvetteclub.com It is located under the C5 performance tips topic. Check it out
Old Jun 20, 2002 | 11:16 PM
G Man's Avatar
G Man
Default Re: Need Help.....DIC Says RF Tire Is Flat (brandonsvett)
Thanks for the replies....I will go through the re-learn tomorrow, and contact Nate. ;)
To Need Help.....DIC Says RF Tire Is Flat
