Do I over-torque the lugs?
Old Jun 20, 2002 | 09:25 PM
NoRice4Me's Avatar
NoRice4Me
Default Do I over-torque the lugs?
I use a torque wrench to torque all my lugs to 100lbs every time the wheels are removed. Today, the 3/8" drive connector on the torque wrench broke off! It's rated up to 140lbs! Am I over-torquing the wheel lugs?!? Maybe, I should be using a 1/2" drive? Is it a bad torque-wrench? It's made in Taiwan, but they're all made in Taiwan!
Also, the tire pros guy said that I shouldn't torque the locking lugs beyond 40lbs, as any more torque will damage them. Is that :bs ?? Maybe I should just torque 'em all to 40lbs?
Old Jun 20, 2002 | 09:29 PM
NassyVette's Avatar
NassyVette
Default Re: Do I over-torque the lugs? (NoRice4Me)
I've always done 75 in a progressive star pattern. 25, then 50, then 75, including the locking nut. Not sure if 75lbs is the proper torque, but none of my wheels has fallen off yet :smash: Someone else will chime in with the "correct" torque. :hat
Old Jun 20, 2002 | 09:31 PM
CJS's Avatar
CJS
I torque my lugs and locking lugs to exactly 100 ft/lbs. Incidentally, I too broke a 3/8" drive adapter (Sears Craftsman) but that was at about 145 ft/lbs. 100 ft/lbs is the correct figure by the book.
Old Jun 20, 2002 | 09:33 PM
Patches's Avatar
Patches
Quote<<tire pros guy said that I shouldn't torque the locking lugs beyond 40lbs>>Unquote
Hell's Bells - a first in the history of tire service. A tire tech who doesn't use the Nuclear-powered pneumatic wrench to weld the lug nuts to the studs???:lol: :jester
Service manual says 100 ft.lbs. so I torque to 35, 70, 100 in a star crossing pattern. Try 40 ft.lbs. and see how low a force it takes to reach that torque. I certainly wouldn't be trying triple-digit speeds with my wheels held on with that little force - would you?
:crazy:
Old Jun 20, 2002 | 09:37 PM
MelloYellow's Avatar
MelloYellow
Default Re: Do I over-torque the lugs? (CJS)
Old Jun 20, 2002 | 10:14 PM
NoRice4Me's Avatar
NoRice4Me
Default Re: Do I over-torque the lugs? (Patches)
The quality of the shops in So Cal have really gone down. I went to this Northridge Tire place since both Rydell Chevy dealers send their cars there and HIGHLY recommended them to me. But I had a pretty bad experience with my wheel swap. The techs just seemed cluessless. I had to go back twice! Once for a poorly balanced LF wheel (strong vibration at 60mph+) and air loss from ALL 4 wheels (6 psi after 8 hours), then again the next day when one wheel still lost 10 psi overnight! Each time they tried to blame the new wheels (thanks to Mike at Xtreme for taking my frantic calls that day)! One tech also mounted the lugs in a CIRCULAR pattern, and when I asked that he use a torque wrench, that's when he fed me the wheel lock not over 40lbs line! At least the manager seemed very apologetic and got to work on things quickly, but I'm not going to trust them with any work in the future! These guys were suppose to be Corvette experts. So if you're getting your wheels/tires serviced at Rydell, just beware!
Old Jun 20, 2002 | 10:48 PM
TooManyIDs's Avatar
TooManyIDs
100 ft/lbs.
I use 1/2" drive.
Old Jun 21, 2002 | 12:04 PM
carpe dm's Avatar
carpe dm
Ditto "Patches"! Do the sequence he recommends or at least, 30 - 60 - 90lbs/ft. 40 might be good for a Suzukimobile. :blueangel: :crazy:
Old Jun 21, 2002 | 12:17 PM
ruking1's Avatar
ruking1
Use a 1/2 in drive. Use 100 ft#'s, for the wheel lug nut lock as well. 100 ft #'s are what is called for in the service manual.
Old Jun 21, 2002 | 12:47 PM
RedLandRocket's Avatar
RedLandRocket
Default Re: Do I over-torque the lugs? (ruking1)
The factory does 125 ft-lb when they initially install the wheels on the line but we should use a minimum of 90 ft-lb when you reinstall.
I always use 100 ft-lb.
Old Jun 21, 2002 | 01:20 PM
JAY KOCH's Avatar
JAY KOCH
Where did you take your car? I am also using Rydell for service and would like to avoid
this tire store.
Old Jun 21, 2002 | 02:26 PM
allanlaw's Avatar
allanlaw
There is only ONE guy at Northridge Tire who knows how to work on Corvettes, or at least that was the case several months ago. I watched him mount and balance my new Firestones (shipped there directly by TireRack), and he was very careful. The lug nuts were properly torqued by hand, and he even knew had to do the relearn for the pressure sensors. However, it was clear that none of the other workers there had a clue. If this guy is gone, then you are correct - this would be a place to avoid. Of course, I can't remember his name (might have been Jose).
Old Jun 21, 2002 | 03:23 PM
NoRice4Me's Avatar
NoRice4Me
Default Re: Do I over-torque the lugs? (JAY KOCH)
Where did you take your car? I am also using Rydell for service and would like to avoid this tire store.
The place is Northridge Tire Pros on Reseda blvd near Nordoff. I complained about them to the service manager at the Van Nuys Rydell, and they said they'll now be using a tire place closer to them (some Cadilliac place - I think).
I don't even go to the Northridge Rydell. They suck BIG time! They had screwed up the front quarter panels on my Z28 TWICE when putting it on the lift. I wouldn't trust them with the C5. The good advisiors and techs that used to work there are now at the Van Nuys Rydell and Calabasas Mercedes.
Old Jun 21, 2002 | 03:35 PM
NoRice4Me's Avatar
NoRice4Me
Default Re: Do I over-torque the lugs? (allanlaw)
I don't remember the name of the guy that worked on my car, but Jose doesn't ring a bell. I remember overhearing the manager Kenny mention something like 'too bad Bernard is on vacation' or something like that in a discussion they were having amongst themselves. Doesn't matter, I'm going back to Stokes Tire in the future, the extra trip to Santa Monica is worth it...
Old Jun 21, 2002 | 04:45 PM
VBP's Avatar
VBP
St. Jude Donor '07,'13
I use a 1/2" drive deep socket with a thin wall and never had any problems. :cheers:
Old Jun 21, 2002 | 05:03 PM
allanlaw's Avatar
allanlaw
Bernard is one of the counter men. Stokes may be the place for me in the future.
Old Jun 23, 2002 | 01:09 PM
Stingray1967's Avatar
Stingray1967
Default Re: Do I over-torque the lugs? (carpe dm)
I do what the book says, 100.
To Do I over-torque the lugs?
