HID headlight conversion problem
Old Apr 28, 2013 | 07:34 PM
redlined's Avatar
redlined
Default HID headlight conversion problem
Just converted my low beams to 35w HID. They light fine however, the buckets will not retract when I turn them off. The only way they will go down is to turn on the high beams and then turn them off. I know this is a common problem but I can't find the fix anywhere. Any help would be appreciated.
Thanks guys!!
Old Apr 28, 2013 | 10:23 PM
darkstar.c5's Avatar
darkstar.c5
that is the typical behavior unless you installed the optional resistor that they offered.
http://forums.corvetteforum.com/1571044730-post2.html
Old Apr 29, 2013 | 08:15 AM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
This has come up several times in the past few weeks. I have the JW resistor on my HID conversion and it works fine. Problem is that when you now go to the JW website the resistor is no longer offered, or at least I can't find it on the site. May be JW can chime in and let us know if it is still available.
Old Apr 29, 2013 | 10:07 AM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Sorry we stopped offering them. They were not working too well with some of the kits C5ers are buying, and we stopped selling ours without a projector swap so they got cut from the line.
Old Apr 30, 2013 | 12:46 AM
Chaplain's Avatar
Chaplain
St. Jude Donor '11-'12-'13-'14-'15-'16-'17
PM sent. I have one with your name on it. You pay shipping and I will send it to you.
Chaplain
Old May 1, 2013 | 08:02 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Thanks guys!!
This worked perfect for a friend of mine recently.
About 2/3 down this page.
http://autolumination.com/equalizers.htm
Toque
Old May 2, 2013 | 12:15 AM
Chicago1's Avatar
Chicago1
That's why mine never worked I always wondered. So what do you sugggest now?
Old May 2, 2013 | 02:47 PM
MN-Brent's Avatar
MN-Brent
You throw on the high beams, then shut the headlights off, and the pods will retract like normal. At least that's how it works on my C5 with low beam HIDs.
Old May 2, 2013 | 03:18 PM
Toque's Avatar
Toque
Spend the $8 and fix it.... See post #6.
Or get the one to the left of it for $13 (the one I use).
Toque
Old May 2, 2013 | 03:58 PM
Chaplain's Avatar
Chaplain
Toque
I still have the freeby which is like the one to the left.
Chaplain
Old May 2, 2013 | 07:04 PM
Chicago1's Avatar
Chicago1
Toque
Can't see it from my phone ill check it out when I get on a pc. Thanks
Old May 6, 2013 | 12:58 AM
Cliff8928's Avatar
Cliff8928
When i do that, i hear a noise up front unless i leave the high beams on. This is with the 55w ACA Bi-Xenon RadioFlyer kit.
Old May 6, 2013 | 01:41 AM
Carlos Arredondo's Avatar
Carlos Arredondo
try covette mods website.
To HID headlight conversion problem
