CD Changer Won't Play
Old Jun 21, 2002 | 10:36 AM
ISLANDBOY2's Avatar
ISLANDBOY2
Default CD Changer Won't Play
I disconnected the battery to check something then later reconnected. Tried to play a CD and the CD Changer did not start. The radio works fine. I think the dealership that did my column lock had the same problem after they disconnected the battery. Before I call or bring it back to the dealership, is there a method to get the CD changer to work after disconnecting the battery? I have a 1999 Coupe, A4.
Old Jun 21, 2002 | 02:05 PM
DPC5's Avatar
DPC5
Default Re: CD Changer Won't Play (ISLANDBOY2)
Take this over to the "Audio/Electronics" section, you'll probably get a better response over there.
Old Jun 21, 2002 | 02:18 PM
MVP's Avatar
MVP
Default Re: CD Changer Won't Play (DPC5)
try waiting five minutes :nopity Mine takes forever to load up when you first put the cartridge in. You will hear it moving around in there.
Hope this helps
Old Jun 21, 2002 | 02:20 PM
lotzahp's Avatar
lotzahp
with the ignition off, load the cartridge of discs and let the changer cycle through until it is quiet - then turn the car on. Sometimes that changer gets confused and this often helps.
Old Jun 21, 2002 | 04:08 PM
ISLANDBOY2's Avatar
ISLANDBOY2
Default Re: CD Changer Won't Play (lotzahp)
Got it working again. Just opened the door and had the CDs cycle themselves again. Turned the radio on and switched to TapeAux and got my tunes to play. Thanks again the help and info on the forum.
To CD Changer Won't Play
