Can't turn the ignition key
Old May 3, 2013 | 03:35 AM
stewbronco's Avatar
stewbronco
Default Can't turn the ignition key
HI all....2000 C5 covertible automatic.
Key [any of 3 ] insert into igntion switch,BUT will not turn ! Car is in PARK!!
Cannot tow due to Transmission in PARK!!
Any ideas.....I think it's the switch....tumblers,but not sure?
Any ideas? THANKS STEW
Old May 3, 2013 | 07:51 AM
woodvette03's Avatar
woodvette03
is your steering wheel straight or turned one way or the other? i had this happen before b/c the steering wheel was turned causing something inside to bind up. try turning your steering wheel and holding it in that position while inserting the key and try to start car.
Old May 3, 2013 | 09:47 AM
MStrahan's Avatar
MStrahan
If it's not the above and you've tried wiggling and shaking the steering wheel, then more than likely your cylinder has crapped out on you. Mine did the same thing not too long ago. The good news is it's not hard to replace if your halfway o.k. with a screwdriver.
I ended up taking my key and leaving it with a dealership to have them set up the cylinder for my key and then I installed the new cylinder in about an hour start to finish.
Your going to have to take most of the console out to get to the cylinder. You can find the write up on that pretty easily. Just search for installing a shifter as it's the same beginning process only you pull the key cylinder rather than the shifter.
Here is a write up I found that Toque wrote. Just ignore the I-pod interface stuff.
http://www.toquez06.com/ipod.html
Good luck.
Old May 3, 2013 | 11:34 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Exactly what I was going to say...
Toque
Old May 3, 2013 | 12:08 PM
NukeC5's Avatar
NukeC5
Toque
haha same here. If your on a hill and the wheel is turned, you will have to muscle it to allow the lock to disengage.
Old May 4, 2013 | 08:49 PM
bighank's Avatar
bighank
Default Its called TORQUE LOCK
If it is then turn the wheel slightly in one direction or the other when trying to turn the ignition key.
Old May 5, 2013 | 02:27 AM
Toque's Avatar
Toque
stewbronco
Its been a few days, have you fixed it ?
Toque
To Can't turn the ignition key
