C5 window
Old May 5, 2013 | 10:22 AM
gordonking's Avatar
gordonking
1st Gear
Default C5 window
Passenger side window is all the way down and regulator is bad. Any way to get it up without removing door panel?
g king
Old May 5, 2013 | 10:58 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
g king
regulators are not available anymore so you need to buy two for 800 bucks. or junk yrad
Old May 5, 2013 | 12:39 PM
Tony P's Avatar
Tony P
I think that the regulators ARE still available. Check out these 2 threads below that tell you what I'm going through on this issue. Seems pretty common.
I will tell you that taking the door panel apart is pretty easy if you are patient and take your time.
http://forums.corvetteforum.com/c5-g...blem-ouch.html
http://forums.corvetteforum.com/c5-g...ubilation.html
Good luck!
Old May 5, 2013 | 04:12 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
They are still availble, both new OEM and reproductions as well as used. Just ordered new OEM for right and left hand sides as my right side is starting to fail. Paid less than $400 shipped for both, they include regulators and motors. Check out the auction sites.
Old May 6, 2013 | 05:20 PM
lwise4's Avatar
lwise4
Default Regulator
g king
I don't think so!
I just replaced my 2003 regulator. I bought a used one from a Forum member for $75. It took about 1.5 hours to replace and works just fine. Rock auto also has them for $130 if you do not want used.
Do a search on regulator and there is a video on replacing it that is very good.
To C5 window
