2001 BCM Pinout Question
Old May 6, 2013 | 10:09 AM
drivinhard's Avatar
drivinhard
Default 2001 BCM Pinout Question
I'm looking at a 2001 diagram and my actual car, and on the 24 way F Micro Pack 100 connector on the BCM, I am seeing a white wire for A6, that goes to the 2nd wire pack of the interior fuse box. However, in the diagram, it's showing a black wire. It's labeled ALC HDLP Relay Control. Right wire but wrong color? Anybody else have a 2001 diagram that can verify?
Old May 6, 2013 | 01:47 PM
dadaroo's Avatar
dadaroo
I can post the connector pins for you, I have the 2001 FSM. Not home now but can do it later for you if no one else beats me to it.
Old May 6, 2013 | 07:37 PM
dadaroo's Avatar
dadaroo
I looked in my 2001 FSM. it shows exactly the same black wire on C1. The only white wire I see is on C2 which is labeled C3 for the RR Defogger Relay Outut-Coil.
What is your issue, maybe I can help?
To 2001 BCM Pinout Question
