Will the 4 Hi Harness fix this issues?
Old May 6, 2013 | 09:13 PM
jgump's Avatar
jgump
Default Will the 4 Hi Harness fix this issues?
I installed the ACA headlamps and used a 35W HID kit on the lows and fogs. I tested it and everthing worked, so I skipped installing the harness that came with the ACA kit. Big mistake.
After a few weeks one of the HIDs (Driver side) stopped working. Basically I can not turn the lights on while the car is on. Only the passenger side goes on. If I shut the car off, turn on the lights, then turn on the car everything works. From reading, this is pretty common and I should have installed the harness while I had it apart. Both the light bulb and balast are ok.
Would the Radioflyer 4 Hi harness solve this issue? It is inexpensive and easier to install.
BTW, my fogs always work, and I have the resistor so the buckets always go up and down.
Old May 7, 2013 | 09:19 PM
jgump's Avatar
jgump
ttt
