At start up this spring, found battery dead...started with of booster pack...started up fine. However... when I try to move car, the motor shuts down. Starts fine, revs fine, but when I try to move the car, the motor shuts down... I'm assuming that the dead battery caused the security system to activate...no lights on dash.
Tried the "remove key..wait 10 sec."....tried " leaving key turned on for 20 min."........ problem still there.
No current codes showing ... older code "P1518-Intake Manifold Control Stuck Open" shows up.
Gives you an excuse to get a Mail Order Tune as well. Besides the performance gain, they can change that 2mph shutoff to a value like 250mph. In case you were out 'n about and it were to happen again, you could then drive it home. This assuming you install a CLB (bypass) so the wheel won't lock up.
