NEED HELP PCM harness repair
I need to repair the PCM harness (obviously), it was pulled out of its connector to the pcm while still bolted so the wires just de-pinned from the connector itself. what tool can re-pin them? I have never had to re-pin before so please explain in detail!
Can the plug that should have been attached to the actual harness be bought new if needed?
