Random no start issue
Old May 9, 2013 | 06:11 PM
rttmike's Avatar
rttmike
Default Random no start issue
I have posted about this before thinking it was an aftermarket alarm issue.
about half of the time I get in the vette, I get in and hit the key. The fuel pump cycles, the gauges all cycle, but the starter does nothing. After I arm and disarm the alarm a few times, (sometimes taking 10 minutes) the car eventually cranks and runs. I did just officially have the VATS shut off so I know this is not the issue.
Also, I went under the dash with a test light. I tested the yellow wire off of the ignition switch. As far as I know, this is the wire that tells the starter to turn over. I have power to both ends when hitting the key. Keep in mind, this wire is in fact spliced into for the aftermarket alarm. But both ends show power when it should.
I did some research on the alarm. I am not 100% certain which one it is but I do know it is made by the same company that makes viper alarms. At this point I am unsure if this is an alarm issue or the car itself. Does anybody have any input?
Old May 9, 2013 | 06:22 PM
maxx2200's Avatar
maxx2200
This just started happening to me as well.
If your situation is a "no crank" type then try this. When you turn the key all of the way to the right to engage the starter (and it does not start), try backing off ever so slightly. Mine starts everytime this way and I think it may be contatcs or the switch itself, I just haven't had time to dig into it.
If this is not your symptom then please disregard. lol.
Old May 9, 2013 | 06:39 PM
rttmike's Avatar
rttmike
I tried this with no luck.
Also I should note that when I do turn the key to tray and start it, I do hear relays clicking.
Old May 9, 2013 | 07:37 PM
racebum's Avatar
racebum
if you hear relays clicking yours is really easy. it's either the solenoid or lack of power. from what i've gathered the c5 staters generally fail at the solenoid.
lot of times there is no noise at all and it still traces back to the solenoid and or clutch switch
vats issues should have the security light flashing
new delco starter is 130 something shipped on amazon and the clutch switch is 6
Old May 9, 2013 | 08:48 PM
Dag Skagney's Avatar
Dag Skagney
I also had intermittent no start issues with symptoms same as yours. In my case it was starter/solenoid. Replaced starter and all good for a few months now. Good luck, hope your issue is as simple as mine was.
Old May 10, 2013 | 07:39 AM
bpenn8966's Avatar
bpenn8966
Had the issue in mine as well a little while back, would start fine 99% of the time, but every once in a while nothting. Turned out the connections on the starter were just loose enough to lose connection and had a slight bit of corrosion on them. After cleaning with a wire brush, some dielectric grease and tightening back down problem was solved, has not happened again. Just something to take a look at too.
To Random no start issue
