Replacing Check Engine Light Bulb
Old May 10, 2013 | 11:44 AM
dadaroo's Avatar
dadaroo
Default Replacing Check Engine Light Bulb
Has anyone done this? I am pretty sure it is soldered into the circuit. I plan to help a friend fix his. Specifically I want to determine the best match for the bulb, not sure if it is the same as for the DIC buttons. I am assuming it would be a bigger bulb.
Just trying to minimize the time his IPC is out of service. If anyone has done this I would also appreciate if it is easliy accessed or if we have to disect some of the IPC to get to it.
Thanks, Mr. Sam
