New LS Timing Cover Alignment Tool! Check it out!
Old May 11, 2013 | 10:16 PM
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Default New LS Timing Cover Alignment Tool! Check it out!
AlignIt Timing Cover/Crank Seal Alignment tool
Here is a simple but very effective tool to help you make easy work of installing your LS1-2-3-6-7-9 timing cover and seal.
The Alignit tool gets the timing cover centered perfectly with the crank and installs the seal in seconds!
Having the seal centered accurately with the crank minimizes the chance of seal leakage. Only $19.95
http://www.saccitycorvette.com/Timin...nmenttool.html
Update! We made a improvement to the AlignIt!
We will have to add a a few bucks to the cost. The New price
will be $26.95.
We will keep the $19.95 price through the Memorial weekend.
After that we will implement the new price.
Also if you purchased a AlignIt without the O-Ring and you would like a O-Ring installed at no charge just send it back to us.
Basically the O-Ring lets the AlignIt fit snugger in the cover holding it in place better.
One other thing, we are working on a Rear Main AlignIt tool.
Here is a video that shows how simple it is to use.
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old May 11, 2013 | 10:44 PM
lionelhutz's Avatar
lionelhutz
Very nice!
Old May 12, 2013 | 10:40 PM
_r2h's Avatar
_r2h
That's slick
Old May 13, 2013 | 12:19 AM
bracketshark's Avatar
bracketshark
Default Alignment tool
I'm looking forward to using mine here in a couple of weeks. The last balancer I changed I guessed at its position and knew then I'd never assemble one like that again. I bought your tool cheaper than I could have made it. Thanks again. Steve
Old May 14, 2013 | 01:39 PM
SacCityCorvette
Supporting Vendor
Thank you bracketshark for your business, we really appreciate it!
Let us know how you like it.
Old May 17, 2013 | 02:54 PM
SacCityCorvette
Supporting Vendor
Weekend Bump!
Old May 20, 2013 | 06:35 PM
SacCityCorvette
Supporting Vendor
We have them in stock!
Old May 20, 2013 | 06:55 PM
maxx2200's Avatar
maxx2200
Very cool.
Old May 21, 2013 | 01:28 PM
SacCityCorvette
Supporting Vendor
Thanks Max!
Old May 25, 2013 | 10:30 PM
SacCityCorvette
Supporting Vendor
Lets remember what this weekend is about!
To New LS Timing Cover Alignment Tool! Check it out!
