When you clean you K&N.....
Old Jun 22, 2002 | 11:07 AM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Default When you clean you K&N.....
..is it desirable to reset the comp by disconnecting the battery?
I found some crude in mine so it may be confused.
Old Jun 22, 2002 | 09:58 PM
MDL-01C5's Avatar
MDL-01C5
Default Re: When you clean you K&N..... (REDGAR)
Crud in what, bro? :confused:
Old Jun 22, 2002 | 10:02 PM
LoneStarFRC's Avatar
LoneStarFRC
Default Re: When you clean you K&N..... (MDL-01C5)
Ezackly!
Crud in yer 'puter? :confused:
Old Jun 23, 2002 | 12:08 AM
viperZ06's Avatar
viperZ06
crude in your what??????? :confused:
Old Jun 23, 2002 | 12:52 AM
robsvette's Avatar
robsvette
Default Re: When you clean you K&N..... (kgrif)
ehhhh? :confused:
Old Jun 23, 2002 | 01:04 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
He means crud in his filter.. no need to reset the computer. It is always learning.. :)
Old Jun 23, 2002 | 01:37 AM
Ironswims's Avatar
Ironswims
St. Jude Donor '11, '13, '15, '17, '19
Default Re: When you clean you K&N..... (CHRIS NJ C5)
What Chris NJ C5 said, once it "sees" greater air flow it will compensate with fuel - the same way it does when new K&N is first installed. I read someplace to be careful not to over oil after cleaning. This could decrease flow, and dirty up a.i.t. sensor, etc.
Old Jun 23, 2002 | 11:15 AM
REDGAR's Avatar
REDGAR
CI VI Drag Champ!
Thanks Chris. I did not reset and also did not see any gain but I guess it needs some time to learn if any increase is possible.
To those that could not figure out what I was asking the tope
is the begining of the sentence and you really need to put the topic together with the subject :jester That is what the dots are for in the sentence.
Old Jun 23, 2002 | 03:45 PM
viperZ06's Avatar
viperZ06
Default Re: When you clean you K&N..... (Ironswims)
What is A I T sensor?
Old Jun 23, 2002 | 05:16 PM
MRWHOOPPEE's Avatar
MRWHOOPPEE
no
Old Jun 23, 2002 | 07:02 PM
LoneStarFRC
:lol: I hate it when that happens! :lol:
Seriously though, check your MAF wires, etc. Sometimes a little too much oil on the freshly cleaned filter will wind up on the wires and inside surfaces. If you do need to do a little cleaning, Q-tips soaked in alcohol and VERY carefully used, will clean them off. As far as re-learn, what the others said is true. :)
Robert
To When you clean you K&N.....
